Old 05-17-2014, 10:10 AM   #15
dznf0g's Avatar
Oswego , Illinois
I still have my (non- recalled, I believe) Actibrake version 2. I would like to offer my theoretical input, drawing on my knowledge of automotive hydraulic power brake systems.
I haven't done my own research on competitive brands of actuators, so I am looking for input, as well as links to be posted to manuals and info relative to operational descriptions.
My belief is that the only way to have no lag time upon application is to incorporate a high pressure accumulator (like autos) so when the pedal is applied you already have pressurized fluid at the ready for brake pad application. Bleeding helps, of course, but the lag time to build pressure creates a delayed application.
-Rich-
Old 05-17-2014, 10:13 AM   #16
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I agree even after bleeding there is a brief lag. Perhaps if the actuator was positioned closer to the wheels there would be no lag?
4RXLA is offline   Reply With Quote
Old 05-17-2014, 01:13 PM   #17
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I have no noticible lag/ delay with mine. When I hit the brakes, my trailer stops..... better than my truck.
Old 05-17-2014, 11:44 PM   #18
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
There seems to be a challenge in these trailer brake pump designs that relates to how fast it pressures the system as well as the feathering, if you will, of how much pressure is generated. Reading other information on line there are many variations on the theme of these brake conversions from drum brakes.
From the sounds I hear, the Titan pump on our unit must be a fixed speed motor and a electronically controlled pressure relief valve does the modulation of pressure based upon the signal coming down the blue wire. So this interaction plays into the issues of any air in the line and the mechanical issue of uneven retraction of the brake pucks due to lateral movement forces on the wheels (scrubbing the tires) when making turns that slightly move the pucks inwards.
This chain of thought would lead one to think we have different "gaps" between the discs and the brake pads as another variable on how quickly brake action starts.
I will become more informed Tuesday when I bypass the Dodge factory brake controller using a DirecLink brake controller.
Old 05-18-2014, 05:33 AM   #19
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Stationary I can press slightly on the brake and hear the Carlisle at a low starting growl or press harder and you hear it ramp up. This is also the Maxbrake doing its job of responding to the brake system pressure.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-18-2014, 05:53 AM   #20
SteveH's Avatar
Common Sense , Texas
We are on a rally this weekend, but on the way here I timed the delay several times and it seems to be right at one second.
While visiting with a friend in the club I learned his 2000 34' SO has Kelsey Hayes caliper which are single piston and so do not have the issues with bleeding as the later model brakes.
Regards,
Steve
Old 05-18-2014, 01:36 PM   #21
SteveH's Avatar
I have done the same test, and when I see the tail lights, I can hear the Actibrake working. However, when driving, there is the slight delay. Don't know if this is normal, or if there is still some air in the system, and really don't know of a better way to bleed them to remove possible air from the inner halfs of the calipers.
Regards,
Steve
Old 05-18-2014, 01:38 PM   #22
SteveH's Avatar
PM me if you have trouble with a warning light remaining on the dash of your Ram after you do this.
Regards,
Steve
Old 05-18-2014, 03:15 PM   #23
GCinSC2's Avatar
Steve,
This is exactly where I feel AS didn't set this up correctly. The hose screws into the junction block on the frame and then the caliper is screwed onto the hose until tight, but if it reached tight and the caliper is out of position, then you have to tighten either or both ends more to line up the caliper w/o any twist in the hose. so now its all tight, but how do you bleed it? No bleed screw on inboard caliper half. Do you want to loosen the hose at the caliper each time you want it to act as a bleed screw? Not ideal in my opinion. My solution was to use a piece of pre-made steel adapter line, IIRC 3/16" inverted flare to M10 Bubble. This was attached to the hose with a 3/16" brake line coupling. Now I can tighten the nut on the steel line with the steel line in any position to keep it from being twisted. Bleeding the inboard requires loosening the nut and it bleeds at the steel line to caliper connection. Not ideal but it bleeds the inboard caliper and doesn't compromise the connection.
Any air compromises the system performance.
Gary
S/OS #001
Old 05-18-2014, 03:29 PM   #24
2006 30' Classic
Milton , Florida
Dexter 1600
So, for those that have replaced the Actibrake with another brand of activator, did you notice a decrease in brake application delay? What brand of activator do you have? ...
We switched to a Dexter 1600 actuator when our Actibrake failed. This choice was driven by the compatibility of the Ford ITBC with the Dexter actuator in 2010. I did not detect any delay with the Actibrake system, nor do I detect any delay with the Dexter system.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 05-19-2014, 01:06 AM   #25
switz's Avatar
2014 31' Classic
Images: 8
Four wires on plug to DirecLink connecting to 2012 Dodge 2500HD
Black +12Vdc thru #10 wire and 30 amp breaker to positive battery post
White -12Vdc thru #10 wire to negative battery post
Red tees into brake lights circuit
Blue cut lead into truck controller plug and cap on truck side. Other end to rear of truck attaches to DirecLink
This is Tuson's work around. Truck never "sees" trailer on blue wire so does not throw a code.
Old 05-19-2014, 05:47 AM   #26
SteveH's Avatar
If your truck is like mine, it will sense the trailer thru the light and battery charge line, and give you a no brakes warning that you can't erase.
This because the factory brake controller is not sensing brakes, and if you remove the factory brake controller you actually get a trouble code because the ECM is programmed for the controller to be there.
Regards,
Steve
Old 05-19-2014, 06:01 AM   #27
Francisco , Indiana
I switched from an Actibrake to a Carlisle. I can not tell any difference between the two. I can detect no lag time at all.
2011 Dodge with factory controller.
My Actibrake failed coming back from the hot air balloon festiva last fall.
Hickory
hickory is offline   Reply With Quote
Old 07-09-2014, 05:11 PM   #28
SteveH's Avatar
Well my Actibrake failed Monday. First a blowout and now the brake failure. Not a good trip. Hope I can make it home without running over someone.
Regards,
Steve
Help, Actibrake Disc Brake Acuator stuck AirstreamGypsy Brakes & Brake Controllers 5 05-19-2007 10:09 AM
Great Actibrake Service! 3Ms75Argosy Brakes & Brake Controllers 1 03-17-2007 11:45 AM
Debugging Actibrake with Kodiak discs and Prodigy controller ljmiii Brakes & Brake Controllers 10 03-04-2007 11:01 AM
Setup of Actibrake with Kodiak disks on Bambi mswartz Brakes & Brake Controllers 18 02-13-2007 10:31 AM
sens-a-brake vs actibrake ljmiii Brakes & Brake Controllers 4 01-29-2007 06:56 PM
