Old 05-25-2015, 01:13 PM   #1
1988 25' Excella
Okeechobee , Florida
actibrake on 1988 Excella AS
The other morning as I was leaving the house, I heard a loud humming noise from my actibrake(sealed unit with brake fluid). When I looked at it, it was hot to touch.I killed the power and the noise went away.I examined the brake away and realized from my father (93 years old who I bought the trailer from 2 years ago) said that the brake away was the original. What was more disturbing is the wires are connected with wire caps and potentially exposed to the environment over the years. My question are thee following:
1.Could the brake away be faulty and caused the humming noise by engaging the brake system while the AS was sitting in the drive way?
2.If so, I'm not sure how long the brake system was on for but it was hot! Could there be damage? I am going to replace the brake away switch this week.
okeejohn1 is offline   Reply With Quote
Old 05-26-2015, 12:33 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
1) Yes if there is a good battery in the trailer.
2) May be.
Be prepaired to recharge the battery(ies) in the trailer.
Also you would want to test the service brake operation and the new breakaway switch operation.
Connecting wires with wire caps is an accepted practice. Typically if there are wire caps the compoenant (in this case a breakway switch) may have already been replaced at one point since the trailer was new. You can use wire caps (or wire nuts) and my suggestion would be to seal them with a liquid sealer and then wrap with electrical tape after installation. Or use butt connectors with heat shrink tubing for the same result.
>>>>>>>>>>>Action
Help, Actibrake Disc Brake Acuator stuck AirstreamGypsy Brakes & Brake Controllers 5 05-19-2007 10:09 AM
Great Actibrake Service! 3Ms75Argosy Brakes & Brake Controllers 1 03-17-2007 11:45 AM
Debugging Actibrake with Kodiak discs and Prodigy controller ljmiii Brakes & Brake Controllers 10 03-04-2007 11:01 AM
Setup of Actibrake with Kodiak disks on Bambi mswartz Brakes & Brake Controllers 18 02-13-2007 10:31 AM
sens-a-brake vs actibrake ljmiii Brakes & Brake Controllers 4 01-29-2007 06:56 PM
