Old 12-04-2011, 12:53 PM   #1
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
ActiBrake, Internal view.
I'll spare most of the long story on this, but this was a recalled/inspected/passed ActiBrake that I chose not to trust, bought a Carlisle, it later had a hiccup (couple of days before summer trip) and that forced me to re-install the old unit for a trip. It didn't last till we got back home. Fixed Carlisle (thanks Barry @ carlisle) and re-installed.
With a recent thread about converting to disc brakes and the good discussion, decided to cut open old unit, to see internals.
Not much fun.
These are a sealed unit, I had to take an old pruning saw to the case in several spots until it opened up.
Observations:
Motor and pump with discharge port to pressure line and my best guess is a dump valve that opens on de-energization to release brakes.
Circuit board, looks a bit toasty in one corner.
Source of leak, undetermined.
The recall inspection procedure has been previously posted and it shows drilling a hole into the case from the BOTTOM. The recall inspection was done at selling dealer and re-installed, I chose not to trust old recalled unit and replaced, my call. When I removed it to install Carlisle, WOW, hole is thru the side of the case, not the bottom. The correct location would have drilled between components, not into one. Notice drilled hole is at the point where the recall instructions show as the drill to depth. Notice that the drill went thru one of the circuit board chips, still have chips of the chip and all of the plastic case to back up drilled in incorrect location claim.
I'm not drawing solid conclusions of how it worked, only observations about basic internal components of ActiBrake.
Gary
ID:	146482   Click image for larger version
Name:	Pump Assy 1.JPG
Name:	Test Drill Hole 2.JPG
ID:	146484   Click image for larger version
Name:	Test Drill Hole 1.jpg
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Anyone using these? Regascoe's Clear View LP Tanks? Phrunes LP Gas, Piping, Tanks & Regulators 2 06-15-2013 06:46 AM
Somes Sound View Campground moparjohn On The Road... 1 09-13-2011 09:31 PM
View from your rear view mirror.... valmog On The Road... 2 08-23-2011 10:20 PM
