Not sure the 99s came prewired. My 97 had the wiring in the harness but did not have the receptacle at the rear bumper or a connection forward.
Take a look under the hood just below the steering column for 4 wires folded back on themselves and taped. Also look inside the drivers side rear frame member. There should be a hole on the inside of the frame about 15 ins. from the end of the frame. The wires will be inside that hole folded back inside.
2004 Excursion 4x4
