Old 10-07-2010, 04:09 PM   #1
1973 31' Sovereign
Fort Worth , Texas
Images: 27
7way fuse??
1973 sovreign
The brakes signals and light in the trailer have worked before.
Just hooked it up to the vehicle to test the brake wires before I put new brakes on. NOTHING was working.
Took apart the umbilical. White wire was loose and off. reattached and checked both ends. Still nothing.
Have power going to the vehicle 7 way outlet.
Is there a fuse somewhere on the trailer?
Steve
We will soon begin traveling with our family of 5 (and a large dog) Looking forward to remodeling our Airstream, awesome adventures, and meeting new people.
www.steventothemax.com
steven2themax is offline   Reply With Quote
Old 10-07-2010, 06:35 PM   #2
Airdog's Avatar
1972 31' Sovereign
Pittsford , Michigan
I have a Chevy Pickup. I had to put fuses in both fuse boxes (under the hood and on the side of the dash on the drivers side) in the truck to get power to the 7 way plug. Is there power at the plug to work the tail and brake lights?
----Bill & Elaine----
TAC # MI-4
Pittsford, Michigan
"part of the "Forbidden Wheels Clubhouse Recon Team"
"Toast is a tool. It ain't Breakfast!"
Airdog is offline   Reply With Quote
Old 10-07-2010, 08:02 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Not sure about a 1973 but I don't believe there was ever a fuse on the lighting circuits from the 7-way. Those are fused in the tow vehicle. You may have a fuse or breaker on the charge line to protect the 7way and umbilical in the event of a short to ground.
If nothing works at all check the fuses in the tow vehicle and the ground connection to the trailer. If everything works when you're hitched but doesn't when your plugged in but not actually hitched on the ball it's probably grounding.
Old 10-07-2010, 08:25 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
Here are some posts about 7-way. The diagram is in the first post.
http://www.airforums.com/forums/f439...tml#post895454
another:
http://www.airforums.com/forums/f37/...tml#post892840
another:
http://www.airforums.com/forums/f447...tml#post889073
more pictures of 7-way on my blog.
Old 10-08-2010, 05:47 PM   #5
1973 31' Sovereign
Fort Worth , Texas
Images: 27
HMMM trailer was plugged in. I will try it without it plugged in and check the fuses.
Steve
Old 10-09-2010, 01:18 PM   #6
1973 31' Sovereign
Fort Worth , Texas
Images: 27
Where would I find the fuse on the charge line?
Old 10-09-2010, 04:24 PM   #7
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
The fuses are all at the univolt, and quite possibly (fuzzy memory) one inside the coach where the umbilical plugs in, under the front windows at floor line. Hope you find it!
tphan is offline   Reply With Quote
Old 10-09-2010, 06:49 PM   #8
Splitrock's Avatar
Above: 7-way tester.
Below: Fuses inside front at 7-way.
Need 12v fuse pjzuk Batteries, Univolts, Converters & Inverters 1 01-21-2010 04:38 PM
Where's furnace fuse? Astrodokk Classic Motorhomes 7 11-15-2009 07:08 AM
Fuse #1 keeps blowing Z33 Electrical - Systems, Generators, Batteries & Solar 12 12-16-2006 08:43 AM
fuse help !!!! Shellie Electrical - Systems, Generators, Batteries & Solar 3 05-17-2006 06:24 PM
Brake fuse Over59 Electrical - Systems, Generators, Batteries & Solar 44 02-13-2005 06:18 PM
