Old 06-14-2006, 10:35 PM   #1
1977 31' Excella 500
plano , Texas
77 Excella 500 Brake Advice needed
I just bought my first Airstream. It is a 77 Excella 500. The current brake system is the older vacuum style system. I was told by the local dealer to scrap this system and go with an electric system. What all is required to convert the system to electric? Also the dealer said he would do it for $1500, is this a good deal? Thanks.
tschat is offline   Reply With Quote
Old 06-14-2006, 10:40 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
tschat,
If it were me, I would replace the actuator with a new electric/hydralic pump like the new disc brake Airstreams have and keep the discs which are much better than electric drum brakes. The new actuator is about $500 to $700, plus installation. If you decide to convert to electric drums. I will take the disc brakes you remove.
Bill
Just my personal opinion
Old 06-14-2006, 11:55 PM   #3
4slice
4slice's Avatar
1977 31' Sovereign
Chase , British Columbia
tschat,
I've got a '77 31' International with disc brakes. When I bought the rig, the p/o recommended that I change the vac/hyd system to electric/hyd. I bought the Carlisle actuator (about $800 USD) in my town and took it with me to where the trailer was in Alberta. Once I made the deal on the trailer, the p/o (an oil field instrument tech) did the change-over in a couple of hours, while I pretended to know what he was doing. He had a work truck full of s/s tubing and fittings, etc. and was kind enough to volunteer his labor.
I've been really happy with the system. My total combined weight is almost 14,000 lbs and the trailer alone can slow the F250 diesel and A/S while descending the mountain roads around home. I just had my local shop replace the brake pads (which I had purchased from Inland) along with a bearing re-pack, and they said that the rotors and calipers were in great shape yet.
Good luck!
Gary H.
"4slice"
Prince George, BC
4slice is offline   Reply With Quote
31' Excella 500 davidz71 1977 Excella 500 5 06-28-2007 09:15 PM
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
30 Footer Advice Needed JaceBeck Our Community 13 10-04-2002 11:51 AM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
