Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-13-2002, 12:27 PM   #1
igor
igor's Avatar
Profile:  1972 25' Tradewind
Bend , Oregon
Question '72 Trade Wind Pigtail Schematic
I need a schematic for the tow vehicle to trailer pigtail. I need to make an adapter from the newer (and less reliable) 7 pin style to the original 6 round pin style. My trailer is 300 miles from here, otherwise I would just use it as a test model!
Les
igor is offline   Reply With Quote
Old 07-13-2002, 01:06 PM   #2
igor
igor's Avatar
Bend , Oregon
Oops, trailer has 7 pin round (signal stat).
Les Brush
Old 07-13-2002, 03:20 PM   #3
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
just did this for my 73. there is a pdf file on airstream's web site with a diagram for the plug. Go to www.airstream.com, and check the "faq" page.
What I found when I disassembled mine was that it did not match the diagram....so somebody probably changed something at some point. either that, or the diagram is wrong. Anyway, I'd double check with a meter to 'really' see what goes where on the trailer. interesting thing was that the colors on the wires corresponded to what the diagram said they should be; they just weren't "where" the diagram said they should be.
Old 07-14-2002, 03:15 AM   #4
igor
igor's Avatar
Bend , Oregon
Chuck,
Thanks, the diagram is how mine is wired! Mine even had the color code on the inside, bottom of the plug. I just needed to know what function each color did so I could wire the new plug. Again thanks a million.
Les
'59 Trade Wind flyfshr 1959-69 Tradewind 192 11-14-2006 11:50 PM
Any Other '59 Trade Wind Owners? flyfshr 1959-69 Tradewind 11 06-02-2006 10:17 AM
Manual for 72 Trade Wind igor 1970-76 Tradewind 10 05-04-2005 09:55 PM
72 Trade Wind Closet Latch Dissasembly igor Cabinets, Counter Tops & Furnishings 3 08-26-2004 07:57 PM
