Old 07-01-2010, 09:47 PM   #1
1971 27' Overlander
St. Louis , Missouri
Question '71 Overlander Brakes locking in reverse.
I'm on my honeymoon right now and we're just north of Mount Rushmore. While we were on the way here I tried to back up the overlander and brakes locked up! I disconnected the umbilical and they released. This happens every single time I try to back up the trailer. Has anyone ever heard of this problem?
Jesse Irwin is offline   Reply With Quote
Old 07-01-2010, 09:56 PM   #2
Sounds lie the back up light circuit is also feeding the brakes.
Old 07-02-2010, 12:28 AM   #3
richinny's Avatar
2011 34' Classic
it is possible that your trailer plug or tow vehicle plug is not wired correctly. if the brakes do not activate going forward, the brake and reverse light wires might be reversed.
Ricky
Old 07-02-2010, 12:33 AM   #4
richinny's Avatar
2011 34' Classic
if the reverse light goes on when you hit the brakes in drive, check for a short like andy suggested.
these diagrams might help:
http://www.airforums.com/forums/f238...tml#post115411
the colors at each connector might not match and need to be verified.
Ricky
Old 07-02-2010, 08:06 AM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
At least you won't roll backwards If it is the back up lights I would just disconnect that one wire and deal with it when you get home..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-02-2010, 08:05 PM   #6
1971 27' Overlander
Thanks everybody. I didn't realize that the color coding changed with a modern 7 pin flat plug. I got that problem resolved. Now I have another one...
reverse, electric brakes
Brakes locking up in reverse GreatPumpkin Brakes & Brake Controllers 16 08-02-2012 01:30 PM
Older style trailer brakes lock up in reverse whitefawn Brakes & Brake Controllers 15 08-01-2012 06:37 AM
Brakes lock up in reverse!!?? bkrome Brakes & Brake Controllers 7 07-23-2009 05:46 PM
Brakes locking up with BMW X3 jpw159 Brakes & Brake Controllers 16 01-11-2009 11:01 PM
71 Overlander Brakes Mr. Gadget Brakes & Brake Controllers 11 06-16-2006 06:20 PM
