Old 03-21-2009, 09:43 AM   #15
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Is that what the unused wire in post 1?
Is it hot with a battery connected?
>>>>>>>>>Action
Old 03-21-2009, 09:50 AM   #16
soldiermedic's Avatar
Florissant , USA
I am curious what people do with the wires that run out to the break away switch to keep them safe from the weather and UV exposure. Anyone have a good idea for this?
I think for my plan, I will have my 7 pin enter the trailer through the a-frame channel, and into a 12v distribution box that I found on etrailer. From there I can hopefully make all the connections without splicing too many wires.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-22-2009, 08:55 AM   #17
1963 19' Globetrotter
Moline , Illinois
The unused wire when made hot, lit up the running light curcuit. I'll just leave it dead. Otherwise everything on my trailer is just as Andy predicted, curcuit breaker and all. My umbilical and the wires for the breakaway run inside the frame from the tongue and back out a hole in the frame at the connection point. Not a lot of fun to get the new cord /wires back through the hole. The new cord is a slightly larger diameter than the old one. With a little filing and lots of effort everything is now in place and ready to hook up. If this winter ever ends I'll be ready to go!
63air is offline   Reply With Quote
Old 03-22-2009, 09:24 PM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Winter ends!!!!!! It ended last week. We are in spring, man!
~ding~
you are now free to move about the country.
>>>>>>>>>>>>>Action
Old 03-23-2009, 05:15 AM   #19
1976 25' Caravanner
Campton , New Hampshire
Originally Posted by Inland RV Center, In View Post
The breakaway switch, must be wire between the 12 volt charge line, and the hot brake line. That charge line, thru a 12 volt circuit breaker, about 50 amps, goes directly to the battery. Never a fuse
I have questioned , as others have , about a fuse in this line . In my '76 the battery power goes to the converter fuse panel and from there is distributed . Both the hot and ground have a 50a fuse , this is from the factory , therefore everything from that point on , including the brakes are fuse protected . It would seem to me that if it were not fuse protected and there was a dead short in the brake wire it would burn up the wire all the way back to the converter which is inside the trailer. If in the brakeaway situation the brakes tried to draw more than 50a it would be because something had shorted because that size wire couldn't support more than that , at that point the brakes wouldn't be working anymore so it doesn't matter.
Were there any years that Airstream didn't have these lines fused ?
ticki2 is offline   Reply With Quote
1971 Umbilical??? jfremstad Towing, Tow Vehicles & Hitches 4 09-27-2007 11:29 AM
Umbilical cord mickleton Electrical - Systems, Generators, Batteries & Solar 4 07-07-2007 10:25 AM
Rewiring umbilical Joe1261 Lights - Interior & Exterior 7 11-30-2006 05:39 PM
brake wire questions hickam Brakes & Brake Controllers 6 05-01-2005 09:19 PM
Crushed Umbilical heyskipper Lights - Interior & Exterior 3 02-23-2003 08:23 PM
