Old 06-20-2005, 07:39 PM   #1
Lanny
lwebb's Avatar
1954 15' Byam Holiday
1955 15' Byam Holiday
Athens , Georgia
Send a message via AIM to lwebb Send a message via Yahoo to lwebb
6 volt vs 12 volt brakes?
I have recently purchased another camper. It's either a 54 or 55. The owner says he believes the electric brakes work fine but he hasn't used them in well over twenty years. He knows little about them and that's a bit more than I know.
I assume since they were made in the mid fifties that they are likely 6 volt. Is that correct? If so can my 12 volt feed be reduced to 6 volt somehow.
I haven't seen the connector as of yet. Would the connector possibly fit my current contemporary connector?
Any advice would be greatly appreciated. I have to pick it up on Friday and it's a 16 hour drive away. It's only a 15 footer so I could tow it without them if necessary.
lanny
lwebb is offline   Reply With Quote
Old 06-20-2005, 08:14 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Ford was the last car manufacturer to make the voltage change. They went from 6V pos ground to 12V neg ground in 1956. GM made the switch earlier. Not sure about when other manufacturers did that.
If it is a 1954 or 1955 trailer I bet it has 12v brakes. If they have not been used in 2 decades, don't place any bets that they are gonna work now even if you did get the voltage correct.
Also older units may have had a connector like a modern one, however the wiring was frequently not the same. IE different pins were wired differently than today.
Check an exterior light bulb is 6v. If it is everything else is likely to be 6v. As far as the brakes go, I would replace them entirely with loaded backing plates and be done with it.
>>>>>>>>>>>>>>>>>>Action
Old 06-20-2005, 09:22 PM   #3
Images: 59
The original set-up on my '59 was 6V brakes and 12V lights. The instructions were to add a variable resistor, if necessary, to reduce the voltage supplied to the brake magnets. This was for the old KH brake controller.
Regardless, the original magnets have the same resistance as the new ones, and if you have a 'modern' brake controller you can likely set the gain so that the brakes work properly, even without the variable resistor.
I have replaced the axle and brakes on my trailer, but the original brakes still worked ok. You need to 'exercize' the shoes and acutator arms if it thas been sitting for a long time. You need to inspect the bearings and seals anyway, so take a look at the brake springs, hold-downs, and shoes at the same time.
It's neither expensive or difficult to replace the whole backing plate assembly if that's required.
Old 06-20-2005, 10:16 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
And if they are older than dirt ----- highly recommended.
>>>>>>>>>>>>>>>>>>Action
Old 06-21-2005, 02:09 AM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
most retail trailer parts places sell fully loaded backing plates in the 40 to 60 dollar range.
cheap at twice the price!
john
you call them ferrets, i call them weasels.
Old 06-21-2005, 05:02 AM   #6
Lanny
lwebb's Avatar
Athens , Georgia
variable control
Thanks everyone, my brake controller has a variable brake intensity control. Sorry I really don't know how these work. Does that mean it is sending more or less voltage to an electro magnet which control the amount of brake applied?
Old 06-21-2005, 07:38 AM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Correct
Your guess is right on the money. Although, if your brakes haven't been used in 20 years, I would highly recommend replacing them right away, as the epoxy holding the friction material to the base, or table, or the shoe is not designed to last that long, and may allow the friction material (the shoe part) to pop off, and lock up the affected wheel. If that happens, you could be replacing a drum, also.
Old 06-21-2005, 09:18 AM   #8
Somewhere , Indiana
Unhappy I agree!
It might just decide to lock-up at the worst possible time (in heavy traffic etc…)
Like my dad used to say (he was talking about cars but I think that it applies) “If you can’t stop it don’t start it”.
Regards,
Henry
axleman is offline   Reply With Quote
Old 06-21-2005, 12:44 PM   #9
Lanny
lwebb's Avatar
Athens , Georgia
Thanks again all. Since it's only a 15 footer, I will just forgo using them at all. The current owner has had the bearings packed and put on new tires so my return journey, while long, will hopefully be uneventful.
Again, much obliged for the advice.
Lanny
Old 06-21-2005, 01:31 PM   #10
Images: 59
Lanny,
Have a safe and boring journey!
Old 06-21-2005, 05:11 PM   #11
Roy B's Avatar
1998 19' "B" Van Airstream 190
Athens , Georgia
Images: 47
Hey Lanny
Saw your post, can't wait till we hit the road for NY with you, will be a blast to see that camper and get it back here in the hills of Georgia. :-)
Roy
Roy B is offline   Reply With Quote
Old 07-13-2005, 09:39 AM   #12
Can someone tell me where I can find a wiring diagram for the trailer coupler. I would like to get the brakes hooked up on a 1972 Sovereign I purchased to use as a utility trailer-it was partially gutted,I finished the job.
BIGGUNDOCTOR is offline   Reply With Quote
Old 07-13-2005, 10:10 AM   #13
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Lanny
I missed this thread when it started, I had the same concern with the 1954 Double Door Liner I picked up in Tampa and towed to So Cal. I was planning on replacing the brakes on only one axle, since it was basically gutted and then towing it back, I would have considered no brakes except for the length - 30' and the distance - 2500 miles.
In investigating the brakes, I discovered that the brakes on a 1954 trailer are completely different from the current style and the drum would not fit over the new backing plate and the also the magnet in the drum was completely different.
Solution, replace both axles and springs with brakes on one axle, will replace the drum brakes with discs during reconstruction. Purchased the axles and springs from Henry at Axis, very satisfied.
Bill
Just my personal opinion
Old 07-13-2005, 11:30 AM   #14
Images: 59
Originally Posted by BIGGUNDOCTOR
. . . . . 1972 Sovereign I purchased to use as a utility trailer-it was partially gutted,I finished the job.
And you want us to condone this?
Welcome to the Airstream Forums.
12 volt
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 04:41 PM
