Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-09-2007, 05:54 PM   #1
Sundance
Profile:  1973 26' Argosy 26
Devils Lake , North Dakota
Question 10 or 12 Inch Brakes???
What size brakes are stock on a 1973 Argosy 26 foot??
I will be pulling off the wheels later this week. (the trailer is not handy right now).
Sundance is offline   Reply With Quote
Old 07-09-2007, 07:29 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
Not to be wise, but they came with both. The only way to tell for sure is to pull a wheel, and measure. You may be able to tell by VIN, but they could have been changed.
Old 07-10-2007, 04:48 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
All Argosy trailers back then had 10 inch brakes, except the 20 models which had 12 inch brakes. The 1974 parts book spells that out.
In 1977 both sizes were used.
You don't need to pull anything off.
The easiest way to tell is look at how many bolts hold the backing plates (brakes) on, from the backside of the wheel.
If the flange is square, it then has 4 bolts, which mean 10 inch brakes.
If the flange is round, it then has 5 bolts, which mean 12 inch brakes.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 07-10-2007, 04:54 PM   #4
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
We need a poll for "Who is da man?"
If the flange is round, it then has 5 bolts, which mean 12 inch brakes...
Ya learn something every day. Thanks Andy.
Tom
Old 07-10-2007, 05:03 PM   #5
Commercial Vendor
Tom
Yeah, me too.
On a second note, I looked up some old Argosy parts books.
I corrected the above post to be more specific.
Sorry if there was any confusion.
But still, the best way, is to check and see how many bolts hold the backing plates on.
That always works.
Inlandrv.com
800-8777311
Old 07-10-2007, 05:34 PM   #6
Sundance
Thank you Andy.......... As usual you are an asset to this site.
Old 07-10-2007, 05:44 PM   #7
Sundance
I have the 10" brakes............... cheaper to replace that's for sure. I know that the 12" would be better but......... $$$$
The brake assemblies I'm looking at are 10" X 2.25" Dexter parts numbers 23-26 and 23-27 Is that right?? Whats the 2.25" for???
Old 07-10-2007, 05:56 PM   #8
Commercial Vendor
10 inch brakes have shoes that are 10 inches in diameter and 2.25 inches wide.
12 inch brakes have shoes that are 12 inches in diameter and 2 inches wide.
In many areas, 10 inch shoes or backing plates cost more than 12 inch.
Why?? Because they sell more 12" than 10".
Inlandrv.com
800-8777311
Old 07-10-2007, 06:04 PM   #9
Sundance
Thanks........ So the pad contact is close to being the same it seems. 12" probably suffer less fade I would imagine.
Brakes working correctly? Dbraw Electrical - Systems, Generators, Batteries & Solar 8 02-27-2007 08:16 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 06:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 08:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 04:04 PM
