Old 12-22-2012, 09:15 PM   #29
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Originally Posted by SteveH View Post
The more air pressure you put in any tire, the more weight it will handle and the more stable it will be on the road. The tire rated for more pressure in a given size will carry more weight, at that max pressure.
If you air an "E" rated tire to the pressure of a "C" rated tire, it will carry no more weight than a "C" rated tire, and if you don't believe me, check the charts.
I don't know how it could be any more simple.
This is true up to the maximum capacity of the particular tire. For expample, adding more than 50psi will not increase the weight capacity of a C tire beyond 1985LBS.
My question is, is there a benefit to using an LT tire over a P-XL tire for a trailer, assuming either tire has an adequate weight rating for that particular trailer.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 12-23-2012, 06:59 AM   #30
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Many of the choices in the 15" tire world will more than safely carry the load of many Airstream models. The 16" tire choices provide more weight capacity for more money (requires 16" wheels as well as tires). One must do some measuring to ensure the 16" tires will not rub the wheel enclosure on the specific trailer in mind.
Many folks float percentages and margins like they were the official word. The trailer axles have a built in safety margin at GVAW. Good tires have a built in safety margin at the weight shown on the sidewall. These margins might be small, but on tires for instance, does every one have a precisely calibrated tire pressure gage? So did we really inflate a tire to 50 psi or was it 48 or 52?
Each individual has to decide how much "safety factor" they want in their tire ratings, tow vehicle payload capacity, axle ratings, "stuff" in their trailer etc. Then they have the opportunity to live with the consequences of their decision.
Old 12-23-2012, 07:08 AM   #31
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
"Many folks float percentages and margins like they were the official word. The trailer axles have a built in safety margin at GVAW"
Careful, blanket statement......your 2013 does.
....but our Classic, not so much, two 3500lb axles on a 7300lb GVWR trailer.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 12-23-2012, 09:07 AM   #32
r carl's Avatar
Lin , Ne
Dont put a P rated tire on a trailer.
Old 12-23-2012, 10:49 AM   #33
2005 28' Safari
saline , Michigan
There are many, many here that would say don't put an ST tire on a trailer.
Kosm1o is offline   Reply With Quote
Old 12-23-2012, 12:16 PM   #34
Thumbs up
There are many, many here who would say you need to do whatever they
have already done.
PFC
"Tahawus"
RLC
John Prine
Old 12-23-2012, 01:30 PM   #35
SteveH's Avatar
Common Sense , Texas
So, what does that leave you with???? Hmmmm?
Regards,
Steve
Old 12-23-2012, 03:50 PM   #36
AldeanFan's Avatar
1977 23' Safari
Why not?
I've read not to use ST tires, not to use LT tires, not to use P tires.
How did my trailer survive since 1977?
Old 12-23-2012, 07:47 PM   #37
switz's Avatar
2014 31' Classic
Images: 8
The 2013 25FB Int'l has two 3,600 pound rated axles and a GVW of 7,300 pounds. The factory sales literature mentions a tongue weight of 833 pounds. The reality of our system is a tongue weight of between 1,150 and 1,175 pounds. When the trailer is not attached, the tandem axles are supporting up to 6,150 pounds at GVW, well below their rating of 7,200 pounds. Also the tires are supporting only that much weight, which is way below either their sidewall rating or the derated capacity.
Old 12-23-2012, 08:21 PM   #38
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
You can also subtract the weights of the tires, wheels and brake drums
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 12-23-2012, 08:29 PM   #39
2005 19' Safari
GLENDALE , AZ
Just my opinions, to be taken with a grain of salt:
* I had P tires on an old SOB that caused the trailer to wobble and oscillate. However, this may have been caused by switching sizes (old size no longer available) and changing tire pressures. However, they were too spongy/springy and amplified road irregularities. In contrast, the triple axle trailer that came with our 27-foot cabin cruiser had P tires on it; and they worked fine and aged out after 20 years! (It now has ST tires on it.)
* Two different brands of ST tires (GYM and Maxxis, 225/75x15) had tread separation on our 19-foot Bambi, and therefore I don't consider most ST brands available on the market to be reliable. However, if Michelin made an ST tire, I would probably have tried them instead of buying 16-inch wheels and tires.
* LT tires and 16-inch wheels may be overkill on your Airstream, but 16-inch wheels make more tire brands and models available (although, in LT sizes).
* The Michelin XPS Ribs (225/75x16) are almost certainly overkill for our 19-foot Bambi. However, after numerous ST tire failures and damage to our Airstream, I was willing to pay about anything to stop the tire problems. With about two years and 15,000 miles on these tires, we have had absolutely no problems; and we no longer worry about tire failures.
The above being stated, the final decision is still up to you. Finding the right tire (at the right price) for your Airstream can be a trial-and-error experience, based on how much you travel and how much you have in your budget. Or, you can go the overkill route and spend more, but possibly save some time and repairs to your trailer in the future.
Unfortunately, buying tires is kind of like the old Fram oil filter commercial, "You can pay me now, or pay me later" (see below).
Old Fram oil filter commercial, circa 1981:
Old 12-24-2012, 10:45 AM   #40
r carl's Avatar
Lin , Ne
Originally Posted by AldeanFan View Post
Why not?
I would not put on st tires either. LT is the logical choice.
Old 12-24-2012, 11:53 AM   #41
Maniacal Engineer
barts's Avatar
Menlo Park , California
I've been very happy w/ the 15" Michelin tires we have on the Tin Pickle... the trailer tracks very smoothly, stops very quickly in concert with the hydraulic disks we added, and we get 14 mpg pulling at 55-60 mph w/ our 1996 Powerstroke.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 12-26-2012, 10:37 AM   #42
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
>>>>>>>>>>>>>Action
