Old 10-28-2011, 12:05 AM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by TRfour View Post
So please tell us all about what " tire dressing was used ", in your're quote. Could it be that they contained an adverse to rubber content of ( Petrochemicals ), that we have since learned are detrimental to rubber!
Now today, some of us older folks are still learning and more importantly want to pass it on to others, ( kind of our job, so to speak in relevance for today ).
With Love,
Hi, all I can say is it was sold in auto parts stores and called Tire Dressing. [usually in a can to be brushed on like paint] There were many different brands, but I never used any of them. I remember one called Tire Black. A lot of people used Armoural too. At the dealer that I retired from, they also used some kind of tire dressing and I always told them not to use it on my vehicles.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-28-2011, 01:04 AM   #16
TRfour's Avatar
Grand Prairie , Texas
Smile Dang! You Could Be Almost As Old As Me!
Now That's Funny!!.. ( WOW, Tire Black was 90% gasoline, and upon or during application, ( if you were afflicted to smoking during the process ), well all I can say is that you didn't come out the n'other side with the same complexion you went in with!!
Only kidding.
Just how many of us have ever gotten it right on the first trip?? Especialy when it comes to rubbers!
Armoural, is still in progress as we are all aware.
With Love,
My photo album; http://www.winnipesaukee.com/photopo...e=22&ppuser=83
TRfour is offline   Reply With Quote
Old 10-28-2011, 05:32 AM   #17
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Hi, I may be old fashioned, but I believe in not putting anything on my tires. I have seen pre-mature sidewall cracking because of tire dressing was used; And a friend of mine used [I believe Armoural] on his motorcycle tires. He was on the freeway, when his rear tire slipped on the rim, broke the valve stem, went flat very fast, and almost went down before he got the bike stopped. I wash my tires and rims with the same car wash solution that I wash my trailer and cars with and that's all.
Just keep 'em real good clean, hold 'yer peeper's real close and pay attention.
Nothing else but air is needed.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-28-2011, 05:39 AM   #18
Skater's Avatar
1995 30' Excella
Bowie , Maryland
You can also buy covers to put on. I have a set that I kept from the B190 for our trailer. They're not that expensive, either, and no risk of petrochemicals leeching the UV protectors out of the tire or whatever... You can put them on and take them off in a couple minutes.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-28-2011, 07:35 AM   #19
1977 Argosy 24
Milltown , Wisconsin
Don't forget to change out the Summer air in your tires for Winter air, when you put your AS away for the cold months.
ventport is offline   Reply With Quote
Old 10-28-2011, 08:03 AM   #20
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Perhaps some nice knitted tire covers would be in order for this winter?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 10-28-2011, 08:29 AM   #21
1969 27' Overlander
Albuquerque , New Mexico
Silicone on tires is fine.
All modern tires have Silicone in their composition. It's stable, and doesn't degrade the rubber in tires. It also helps with rolling resistance. Check the Dow Corning website for more information.
It works fine on vehicle tires, but should NEVER be used on motorcycle tires because they'll lose traction in turns. Bikes use the sidewalls in turns, cars don't.
Silicone does not have UV inhibitors and makes the tires nice and shiny.
With that said, the tires need to be nice and clean first, or you'll just put a layer of Silicone over dirt and grime (or soap), and the tires will look splotchy and streaked after a short while. Clean them really well, rinse them, and dry them off, first!!
Also, the vinyl product sprays, like Armorall, WILL degrade plastic, especially if they're exposed to high UV sunlight and heat, like dashboards or tires. I won't use the stuff anymore.
As for UV protection, there's only so much you can do, ie: tire covers, etc.
Remember, tires wear out after 5-7 years anyway. Even Oxygen will deteriorate rubber. You'll have to replace them every 5 years or so, even if they have low miles on them. "Cost of doing business." as they say.
edglenn is offline   Reply With Quote
Old 10-28-2011, 11:43 AM   #22
chisholmjb's Avatar
1986 32' Excella
1986 32.5' Airstream 325
Johns Island , South Carolina
Cool thanks all
So I see ,some things could be bad. Covering only makes since . What.about.jacking it.up to letting them sit.on ground, cement,wood etc.
chisholmjb is offline   Reply With Quote
Old 10-28-2011, 08:26 PM   #23
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Regular use will help prolong tire life! Just like most other things in life.
Regular use promotes the transfer of natural oils in the rubber to help protect against UV deterioration and cracking.
Always cover your tires, even if they are on the shady side.
If you want to get real fancy, try NITROGEN.
http://www.google.ca/url?sa=t&rct=j&...IlMTFTvjqLfA7Q
Dave
Old 10-28-2011, 09:04 PM   #24
Salem , Oregon
Images: 18
Hi, I tried using Slilcone on my tires and the only thing that happened were that they went from "C"s to "D"s.
2005 Safari 25-B
Old 10-28-2011, 09:14 PM   #25
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I tried nitrogen once and haven't been able to kick the habit every since. I wake up, look around, and take a breath, and there it is again. I figured if I moved to Colorado, at high altitude there'd be less of it, but it's everywhere and I have to have it. I cover my tires because I'm embarrassed—it has gotten into them no matter whether I use summer or winter air.
It is getting worse—I'm doing argon too.
Gene
Old 10-29-2011, 04:48 AM   #26
Dave
I can't see pay'n for that extra 21.2%.
Regular dry old atmosphere is good 'nuff for me.
PFC
RLC
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
