Old 06-15-2016, 01:07 PM   #1
Ravenna , Ohio
Why tires fail
Tires fail from two basic causes.
Low air pressure
and/or
Long term degradation of the rubber usually from excess heat.
Low pressure (active leak from puncture or loose valve stem or valve core are most common reasons) can lead to a Sidewall Flex failure or more commonly called a "Blowout". The sidewall cord can melt (polyester) or fatigue (steel). Many TT owners fail to realize that they will never "feel" the results of a tire loosing air till it is too late and they are surprised when the sidewall lets go. The rapid air loss "bang" even when the tire only has about 10 to 20 psi in it, is a big surprise IF they even hear it. HERE is a post on how to know if you have a run low flex failure. A TPMS can provide warning of air loss so is good insurance and can easily pay for itself.
The long term degradation of the rubber at the edges of the belts can lead to a belt and/or tread separation. Even if the tire keeps its air you can have this type of failure so a TPMS will not provide a warning. This degradation comes with age as rubber is always loosing flexibility. Just think of those rubber bands you found in the back of the desk drawer. Even in cool and dark they got brittle. HOWEVER running at or near or above the load capacity of a tire will result in increased heat generation. Increased heat actually can accelerate the aging process with a doubling of the rate each increase on 18F. Running a margin of at least 15% between capacity and measured load is a good first step. Running at higher speed will also generate excess heat.
Realizing that over half of the RVs on the road have one or more tire in overload is one main contributor to the high tire failure rate. Simply thinking that a tire will fail because the tire plant building is painted blue rather than green is not logical.
Buying the lowest cost "no-name" tires is IMO a major contributor to poor results. If the main objective is the lowest cost tire why would anyone be surprised with short tire life.
Just paying more however is no guarantee of better quality. I believe the best tool available is comparing Warranty and service support.
Can you get multi year warranty on the tires? Is it possible to get Road Hazard coverage? Is there a nationwide network of dealers who stock the brand you are considering?
Tireman9 is offline   Reply With Quote
Old 08-15-2018, 10:06 AM   #2
Ravenna , Ohio
Due to high levels of Interply Shear (Google the term to learn more) on multi-axle trailers the best approach is to inflate your tires to the tire sidewall max. ALSO confirm with actual scale readings that you have no more than 85% of the tire ststedload capacity on the tires.
Retired tire engineer (40 years). Write a blog on RV tires.
Why tires fail Tireman9 Tires 45 09-23-2013 07:43 AM
OP-ED: Why Clubs Fail - My Opinion mistermike WBCCI Forum 0 12-31-2009 05:47 AM
Goodyear Marathons from 06 and 07 fail... norsea Tires 10 03-03-2009 09:13 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
