Old 04-29-2008, 01:28 PM   #1
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Why not upgrade the tires on my Bambi?
I'm about to buy new tires to replace the originals on the 2000 19" Bambi I just purchased. Airstream installed 225/75-15R ST tires in load range C. That means they are rated for 2150# each at 50psi inflation. With the trailer rated at 4500# gross that seems underrated. I realize that several hundred pounds are carried by the hitch, so the load should be within the range of the tires. However, for a few bucks more, I can go to a D rated tire of the same size. It is rated at 2540#, so the safety margin is increased. The D rated tires are run at 65psi inflation, so there could be less rolling resistance (and better mileage) although they would ride harder.
Stay with C rating or move to D? Any negatives?
robert claus is offline   Reply With Quote
Old 04-29-2008, 01:42 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If it was me, I would go with the Ds. The Bambi may ride slightly harsher, but it would give me more peace of mind.
I have a 25FB that came with D's. I had 3 sepatate blowouts on the road last year with OEM Goodyear Marathons. I watch tire pressure like a hawk, so I figure that my tires were new old stock when they were put on at the factory. These tires only had about 12,000 miles on them.
No longer trusting the Marathons, I went to complete set (4) of Maxxis load range Es. I run them at 70psi. I have now covered another 15,000 miles and have not had any problems.
Brian
SuEllyn & Brian McCabe
Old 04-29-2008, 02:26 PM   #3
_
Originally Posted by robert claus
...Stay with C rating or move to D? Any negatives?
hi robert
i'd go with the d rated tire and inflate as dictated by load.
u fail to mention IF there has been any issues with the current tires...
like blow outs or excessive wear and so on...
i followed a newer bambi a few miles last year and every rr track or dip or bump...
the tires would compress and flatten out like marshmallows...
it looked scary; in talking with the owner later he had 3 blow outs in 2-3 cross country trips...
he was also a bit over the carry capacity.
cheers
2air'
Old 04-29-2008, 02:35 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I think the "D's" have it.
Better to have more than you need, than need more than you have...
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-29-2008, 07:00 PM   #5
2000 19' Bambi
Done - ordered the D rated tires from Tire Rack. Thanks, everyone!
Old 04-29-2008, 07:52 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Hi Robert. Nice to see another "local" here.
My 2003 19' Bambi had D rated tires. I think going D rated is an excellent idea...Airstream does too since that's what they did a few model years later on the same unit!
Hope to see you at the Midwest Forums Rally near Bloomington/Normal this year.
Old 04-29-2008, 08:04 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
My '06 19CCD came with LRD 225/75-15 Marathon's . I dumped them after the first season and went with BFG Commercial T/A 227/75-16 LRE tires that have a 2860lb capacity per tire at 80 psi. I only inflate them to 65, and am much happier and sleep better knowing that I don't have to worry about all of the potential Marathon 'issues'
Old 04-30-2008, 05:01 AM   #8
1984 31' Excella
Norfolk , Virginia
Images: 11
Upgrade Tires
Ditto lewster.
Beginner
Beginner is offline   Reply With Quote
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Bambi Quick Silver Axle upgrade. HOG-I Axles 2 10-30-2007 11:04 PM
16' Bambi Axle/tire/brake upgrade ljmiii Axles 2 02-26-2007 04:46 PM
Bambi upgrade to group 31 battery? rfield54 Electrical - Systems, Generators, Batteries & Solar 0 05-17-2005 09:33 AM
Flat Tires on 2001 Bambi pfishman Tires 2 01-07-2005 12:31 PM
