Old 10-17-2016, 03:45 PM   #99
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
Sorry but Michelin LT Tires do not have the same load capacity as an ST or RH tire. I think most people that switch tires just do it to go faster that 65 mph. In the north the speed limit might say 80 but I still plod along at 60-65 mph. I see plenty of trailers pass me by. So it leads me to believe they just want to go zoom zoom.
Barbieri is offline   Reply With Quote
Old 10-17-2016, 03:47 PM   #100
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Some of those that go zoom zoom also go boom boom. Which reminds me of a saying from some time ago. Speed Kills.
>>>>>>>>>>>>Action
Old 10-17-2016, 09:14 PM   #101
2007 22' International CCD
As an engineer, I would say speed does not necessarily kill, but a big difference in velocity certainly will.
(Yeah, I'm being a pedantic PITA again)
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 10-17-2016, 09:22 PM   #102
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Better check your statement. Any brand 16" LT tire has as much or more capacity than an ST tire plus being a better made, safer tire. LT's are used everyday in the real world on much heavier trailers.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-17-2016, 10:45 PM   #103
2012 19' International
Southeastern MI , Michigan
Doing 60 on freeways through the city where I live will probably cause a wreck. I try to go with the flow and I wouldn't drive on a tire rated at 65 mph max even if I only did 60. Statistically a small percentage of drivers will always be going faster and that's OK. As an engineer I know there is margin in load ratings but would rather not be a test pilot.
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 10-17-2016, 11:08 PM   #104
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
May be. And I have driven I75, 275 and 94 in all hours. If one stays in the slow lane there will be hacked off drivers behind. And there may be a wreck however it will be from the drivers behind the trailer fighting to merge left.
Which is nothing on CA freeways where on some interstates the speed limit is 70 for cars and 55 for trucks and vehicles with trailers. Other freeways and highways the speed limit is 65 for cars and vehicles with trailers are still 55 for the entire state as far as know. With double or more of the amount of traffic than anywhere in Wayne county.
>>>>>>>Action
Old 10-18-2016, 02:17 AM   #105
1991 25' Excella
Stanfield , Oregon
Why does everyone on here compare all St tires with junk Goodyears? There are really good St tires out there you just have to find one that's right for you.
SpletKay06 is offline   Reply With Quote
Old 10-18-2016, 03:38 AM   #106
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Yea tight! Made in China or tiawain, around $100, michelins are around $170, you always get what you pay for, there aren't any bargains out there, been there and done that...
Old 10-18-2016, 04:44 AM   #107
2014 27' Flying Cloud
Wenatchee , Washington
Why Michelin tires?
+1. It's mostly about the the conditions in which you're driving. I really don't feel like I'm driving unsafely when I'm doing 75-80 across Wyoming during the day and the weather is good. (I do slow down at night, during inclement weather, in construction zones, on rough roads, and when nearing a city however for obvious reasons.) YMMV.
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 10-18-2016, 05:48 AM   #108
Gainesville , Florida
Incorrect, my LT firestones have the same or higher weight rating as any ST tires I could find. Weight rating 117, I think.the michelins have thr same rating as the firestones.
Old 10-18-2016, 07:26 AM   #109
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When looking at the load tables for a specific LT Load E tire for Michelin and other brands like Firestone, the load ratings were the same for each 5 psi increment in tire air pressure.
The 2014 31' Classic (GVW of 10,000 pounds) came with 15" GYM ST225/75R15D tires that were rated 2,540 pounds at 65psi. They were replaced with Michelin LT225/75R16/E LTX M/S2 tires that are rated 2,680 pounds @ 80 psi. So the Michelin have additional load capacity, no rational speed restrictions (the sidewall restriction of 65mph is on the GYM tires).
Old 10-18-2016, 11:08 AM   #110
>>>>>>>Action
The key is not to panic and swerve when you're cut off. I'd rather trade some paint and have the other driver ticketed/wrecked than swerve and have a single-car accident/wreck my Airstream and have a citation for that.
Hensley Arrow hitch
Old 10-18-2016, 11:41 AM   #111
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
+1 ^^^^
>>>>>>>>>>>>>Action
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Eddie Bauer AS uses Michelin Tires? Secguru Tires 67 05-29-2014 12:33 AM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
