Old 07-07-2016, 07:44 AM   #57
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
With the Dill TPMS, make sure the installers mark the letter of the sensor/sender they put inside the tire on the wheel. The Dill receiver has a "chip" for each sender that is repositioned in the display module when the tires are rotated.
Old 07-15-2016, 08:56 AM   #58
2004 22' International CCD
Port Orchard , Washington
2004 22' CCD Wheel upgrade 14" to 15"
Hello,
Has anyone upgraded a 22' CCD from 14" to 15" wheels successfully. I have read lots of posts and have conflicting information. I would like to do this upgrade and would like to hear from anyone that has successfully completed this change.
inthralled is offline   Reply With Quote
Old 07-16-2016, 05:41 AM   #59
switz's Avatar
2014 31' Classic
Images: 8
I used the 15" SenDel T03-56445 wheels and prior generation Michelin LTX {P} 235/75R15 XL tires side wall rated 2,183 pounds and derated to 1,985 pounds for trailer use. My heaviest loaded wheel is 1,360 pounds and the the trailer scales at 6,063 pounds with 968 pounds tongue weight. We have two 3,000 pound rated axles.
I also used the Centramatic "200-221 standard" wheel balancers and McGard 24138 Wheel locks and 64010 regular lug nuts. The McGard were from Amazon and the Centrmatics were ordered direct from them.
Old 07-16-2016, 07:58 PM   #60
SilveradoTX's Avatar
2016 27' International
Hockley , Texas
Peace of mind......
Changed Airstreams 15" Goodyear Marathon's for 16" Michelin LTX M/S2 225/75R16 E rated at 80 lbs max, load rating 2680 lbs at 80psi. Had "Discount Tire" mount them on Sendel T03BM trailer wheels.
The reason: While towing a fifth-wheeler for 12 years, had three blow outs and luckily found a sidewall bulge in a fourth and replaced it before it blew. This occurred with three different brand trailer tires. I am always meticulous in maintaining tire pressure. Most rv trailer tires are made in China and manufacturing defects are much more common than American made light truck tires. I have run Michelin tires on my trucks for over 20 years never had a blow out. Any tire is susceptible to blow out or flat due to puncture or road hazard damage, but I have a great (peace of mind) knowing I've got Michelins on our "Silverado". Keep in mind that you loose about 200 lbs load rating capacity for every 10 lb psi drop in tire pressure below max psi
SilveradoTX is offline   Reply With Quote
Old 07-16-2016, 10:23 PM   #61
2014 25' FB International
Metuchen , New Jersey
Thanks SilveradoTX, that's exactly the user experience post I was looking for.
How much did you pay for the rims and tires? Did you go to your trailer dealer to switch them out, mechanic, or did you do it? Since the tires are larger wouldn't you have to adjust the hitch setup as well?
GenXair is offline   Reply With Quote
Old 07-18-2016, 10:41 PM   #62
Hockley , Texas
Hello GenXair, $174 for the tires, $145 for wheels....total for five (w/spare) including mount, balance, shipping & handling and tax $1,871.00
I took factory wheels/tires off and installed new ones myself.
Only 1" difference in overall diameter between factory 15" Marathon's and 16" Michelin LTX M/S2 225/75R16, that translates to only 1/2" higher from ground to axle. I did readjust my equalizer hitch but it was minimal and not sure it was worth the sweat. If you take your Airstream to any tire shop, be vigilant and make sure they place the jacks on underbelly where clearly marked by Airstream to avoid damage. Hope this was helpful.....Laus Deo
Old 10-07-2016, 10:11 PM   #63
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
I have four trailer tires on my airstream and each can handle 2830 lbs at 80 psi. So from what I have researched you are 1000 pounds short of what my tires can handle. So what are so good about Michelin LT tires that everybody is rushing out to buy? Please don't tell me better braking or softer ride. In a travel trailer you don't ride inside and braking differences would be negligible.
Barbieri is offline   Reply With Quote
Old 10-07-2016, 10:26 PM   #64
2007 22' International CCD
In my experience GYM tires are unreliable. We babied ours, checked air pressure every day, etc. Never overloaded the AS, never went over the tire speed limit. Tire threw a tread, did $4500 worth of damage to the wheel well and all the stuff under the kitchen cabinet in one shot.
We're talking a tire with less than two years and under 5,000 miles on it. Will never put an ST tire under this AS ever again, especially Goodyear crap.
Have run Michelin tires under all kind of conditions, and even a set that was totally dry rotted and cracked from desert sun NEVER failed me.
I can select an appropriate Michelin tire to take the load of my AS with appropriate margins. And avoid all the pain.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 10-08-2016, 03:47 AM   #65
2005 19' Safari
GLENDALE , AZ
See Preliminary Comparison of ST to NON-ST Tire Failure Data - As of 10/07/16.
Old 10-08-2016, 05:01 AM   #66
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
In answer to your question, because they work, ST tires no longer do.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-08-2016, 05:44 AM   #67
FCStreamer's Avatar
2014 30' Flying Cloud
My ST tires work fine. Michelin makes great tires, only problem is that they are not designed for use on trailers. Some tire retailers won't even install them on Airstreams for this reason. Yet many people still do and many report good results. I am happy for them.
If you intend to replace your tires, you can either go by the internet wisdom of this board and choose tires from a manufacturer that says they are not designed for trailers, OR you can buy from a manufacturer that says they make tires specifically for your trailer.
Your trailer, your choice.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2013 Cadillac Escalade Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-08-2016, 06:30 AM   #68
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Yes my trailer, my choice. Agreed.
Why does AS have the Michelin as an option and when we toured Jackson Center they were in the lobby for sale?
My rig is one of the heaviest AS tandem axle trailers ever made.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-08-2016, 06:34 AM   #69
FCStreamer's Avatar
Well, Airstream puts GYMs on most of their trailers, so I wouldnt be using Airstream's choice of tire as a reason for me to buy mine.
Airstream makes fine trailers. They don't make tires. They just buy them.
I'd rather look at what tire manufacturers say about their own tires.
Old 10-08-2016, 07:55 AM   #70
GCinSC2's Avatar
Your trailer your choices.
I see the GVWR on a '17 30' FC weighs less than the UBW on my 30' S/O. A lot less.
I bought my trailer 3 yrs old and the left frt tire was replaced already didn't ask didn't know better. A few months later found GYM belt separating on curb side tires. Replaced all with more GYM's while in camp site a few months later. Yes, I did the R&R. The new GYM's developed sidewall protruding bulges. Tire retailer replaced all 4 with maxxis.
No more GYM's for me. The maxxis did fine until the surge of ST issues focused my attn on the problems.
S/OS #001
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Eddie Bauer AS uses Michelin Tires? Secguru Tires 67 05-29-2014 12:33 AM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
