Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 03-12-2012, 03:26 PM   #1
TankerIP's Avatar
2002 22' International
2019 25' Flying Cloud
Why bad tire wear?
What could be the cause of this bad tire wear? I just replaced the bad tire in preparation for our upcoming trip. My other 3 tires all appear in pretty good shape. This one tire (front driver side) I first noticed wear on one side during our long trip last summer. I thought then that the cause might have been some almost "panic stop" as we came out of Colorado/New Mexico mountains. I intended to check it out, at home, just before our next long trip.
The tires are a little over 4 years old. The brakes seem okay. The brake "drag" is the same on all wheels, so I can't see any reason for adjustment there. The bearings were professionally repacked at Jackson center two years ago during our floor replacement.
Does the wear pattern on this tire give anyone a clue as to what might be the problem. It's worst on the inside of the tire. What can I check at at home myself? I plan on putting the new, balanced tire on and proceed on our trip. And --- keep some kind of watchful eye on that particular tire.
Normally, I would have planned on replacing all 4 tires within a year to 18 months anyway. But, I would have never expected to see this kind of tire wear on a trailer. When I replaced the tires 4 years ago all treads were in great shape...I just replaced because of age. So something has changed since then to cause this problem.
ID:	153189   Click image for larger version
TankerIP is offline   Reply With Quote
Old 03-12-2012, 03:28 PM   #2
dznf0g's Avatar
Oswego , Illinois
I would suspect a bent spindle or axle shaft on that corner.
Are you sure the bearings are not loose on that hub?
-Rich-
Old 03-12-2012, 04:37 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
As simple as you may think....the tire pressure looks like it was low. Even if you check it at the beginning of a trip, keep tabs on it.
Old 03-12-2012, 05:07 PM   #4
Retired.
. , At Large
I have seen broken belts cause that as well.
Old 03-12-2012, 05:19 PM   #5
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
It looks like mine did before having the trailer axle aligned. We ate a brand new tire to the belts in less than 1800 miles. After an alignment and four new tires, 3000 miles later they all look like brand new.
Did you clip a parking bumper, curb, deep pothole or something?
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 03-12-2012, 05:26 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Tank',
Low pressure causes the outsides of the tread to wear first. High pressure causes the center to wear first. Out of balance can cause one side to wear. A bent spindle or a loose nut holding the wheel onto the spindle could also be a problem.
One side is worn almost all the way, the other side is worn more than the center. Could be two problems.
A weight may have come off without you knowing it, or an old tire not balanced since it was new may be out of balance. The castellated nut (looks something like a castle) that holds the wheel on could come lose if the cotter pin that goes through it has broken off. There's a cap over the nut that has to be pried off to see it.
The most likely thing is air pressure and/or balance. But check the nut and see of the wheel wobbles when jacked off the ground. A properly tightened nut is slightly loose and you can move the wheel slightly. If the spindle is bent it may be obvious or not—a good tire shop should be able to check that. If Terry says a broken belt could be the problem, I'm sure that is another possibility.
To keep wheels balanced, you can install Centramatics (around $400) and you can keep on eye on tire pressure with a tire pressure monitoring system (TPMS: around $400). You can check tread wear with a tire tread gauge ($10-15) and find out what is wearing faster before you can see it with your eye.
Looking straight on, the "good" tire doesn't look all that good. It may just be the perspective.
Gene
Old 03-12-2012, 06:23 PM   #7
TankerIP's Avatar
Thanks for the info...
Actually the other picture is not a "good tire". It's the same bad tire, but just another side of it that is not as worn.
The other 3 good tires are much, much, better than this.
Old 03-12-2012, 06:26 PM   #8
dznf0g's Avatar
Oswego , Illinois
OOOHHHHHHH, that changes things for me then. I'm with the broken belt crowd now.
-Rich-
Old 03-12-2012, 06:41 PM   #9
Elkhart , Indiana
I am changing also. I thought they were two different tires. My out of line tires looked the same all the way around the tire, not just one side top to bottom.
I would replace just the one and keep an eye on it for a while.
Mike
Have a great day!
Old 03-12-2012, 07:00 PM   #10
richinny's Avatar
2011 34' Classic
one more vote for a bad tire. put an old tire in that location and put the new one somewhere else. if that location continues to wear you killed a tire that has aged out anyway.
Ricky
Old 03-12-2012, 07:09 PM   #11
Master of Universe
Gene's Avatar
Me too.
Gene
Old 03-12-2012, 08:13 PM   #12
2004 16' International CCD
Orem , Utah
If that was mine
I would have bearings replaced and also an alignment after. At very least check bearings and pull them. That is not just tire
starcraft is offline   Reply With Quote
Old 03-14-2012, 04:55 PM   #13
TankerIP's Avatar
New Tire is on
I took richinny's advice and moved the back tire to the front and installed the new tire in it's place. The two are shown below. Interesting note is that the back tire is a little bit more worn on the outside edge. Where the bad tire was worn on the inside edge. Well.....we will see what happens after a couple of thousand miles trailering. Now I'll have to start looking for good sales to replace the older tires.
I checked the bearings for visible grease, no unusual play, and free rolling. All seemed good to me.
ID:	153383   Click image for larger version
Old 03-14-2012, 05:08 PM   #14
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I still go with pressure. Not hard over...but, lets check it all. I always like a cheap fix. (I don't mean "CHEAP" fix....just an inexpensive one.
Old 03-14-2012, 05:25 PM   #15
Retired.
. , At Large
I'll throw a wrench in the works. Is that wheel locking up when you apply the brakes? I still think it's a broken/separated belt, but I don't want anyone to fixate on one potential cause to the exclusion of all other possibilities.
Old 03-15-2012, 01:58 PM   #16
TankerIP's Avatar
Originally Posted by overlander63 View Post
I'll throw a wrench in the works. Is that wheel locking up when you apply the brakes? ...
I worried about brake locking at one point a few months back. We were camped in Taos at a gravel/sand surfaced site. On the way out, I had my wife drive through the lot while I walked beside the tire. I had her apply the brakes several times to see if that one wheel would lock before the others. Nothing unusual happened. No skidding or panic grabs that I could see.
Then just the other day when I jacked the trailer up to change the tire, I pulled the safety switch on the front, to engage the brakes. The brakes did not completely lock, but both wheels on that side with the bad tire had about the same amount of brake energy applied. With a little effort I could turn both wheels about the same.
Frankly, I couldn't think of any other check that I could do on the brakes.
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
Centramatics reduce tire failures? boondockdad Tires 35 03-11-2012 09:08 AM
Tire Recommendation 2006 25' Safari jhohe Tires 3 03-08-2012 05:49 PM
Front mounted spare tire ideas? dryenko Wheels, Hubs & Bearings 6 03-08-2012 02:00 PM
