Old 11-20-2007, 01:18 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
White Tire Paint
I painted the tires on my TW with a rubberized paint and now have WIDE WHITES. I'm very pleased with the results. The stuff is special ordered from Iceland. For tandems you will need 2 cans. I like the way the it goes on thinned a bit. Toulene is the only recommended thinner. A can is $20 and shipping for 1-4 cans is $20. The main problem in applying is chemicals in the rubber tend to bleed through. That problem is largely solved by cleaning the tire with Westley's Bleche-Wite which is recommended by the manufacturer and I found at NAPA for a few bucks. Here's the poop:
White Wall Tire Paint for Mercedes-Benz Pontons
orn.siggurdsson@edda.is
Old 12-04-2007, 09:30 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I miss whitewalls. Been using Westley' Bleche-Wite for over 30-years as it is an excellent tire cleaner. And wheelwell cleaner.
I haven't seen whitewall paint in I don't know how long. Hope it works well for you.
My trailer would be "original" with small stripe whitewalls, too bad trailer tires aren't made this way any more.
Old 12-04-2007, 09:50 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You'll recall what Patton said about pearl handled revolvers? Actually, they lok pretty cool. Kudos
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Paint Roof White trevisgardne Roof 30 10-01-2012 06:42 PM
White Gas? doorgunner Stoves, Ovens & Microwaves 31 04-14-2008 02:15 PM
Argosy white touch-up paint? Dave and Pat Clearcoat, Exterior Paint & Trim 8 05-26-2006 05:33 AM
Paint stovetop with high temp paint? ironfem200 Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
White Paint for roof ? Davis Clearcoat, Exterior Paint & Trim 8 05-30-2004 03:35 PM
