Old 04-29-2013, 10:04 AM   #1
2004 34' Classic S/O
San Antonio , Texas
Which Tire is best
I recently bought a 2004 34' Classic which needs 6 new tires. The trailer still has the factory 15" wheels, which I want to keep. This is my first trailer and I am unsure which tires to get. Any advice/suggestions would be appreciated. Thanks.
Go_Navy is offline   Reply With Quote
Old 04-29-2013, 10:21 AM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Start here Tires - Airstream Forums
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 04-29-2013, 10:38 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Oh no, not again!
Go_Navy, tire questions are often asked and are debated endlessly.
I would suggest replacing them with Goodyear Marathons, which are probably what it has now.
Old 04-29-2013, 01:17 PM   #4
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Thanks Jammer- I am here to post a thread titled tires- thoroughly confused. I've been reading all sorts of posts.... Isn't there some more or less simple answer?
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-29-2013, 02:50 PM   #5
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
There has been a lot posted about tires. You need to decide what you are comfortable and safe with. First, what type of tire - ST or LT ? Then what size - 15" or 16" ? Then what manufacture ? All has been talked about here, on this forum. Happy hunting
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 04-29-2013, 03:52 PM   #6
San Antonio , Texas
Thanks. I will be keeping the 15" rims. So that part is an easy decision. I dont know which is better the LT or ST tires and frankly dont know anything about tires. I have read so many meandering posts about tires on this website..I was hoping for a pretty simple answer/recomendation on which brand and which type (LT or ST).
Old 04-29-2013, 04:34 PM   #7
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I had Maxxis tires on our '85 Excella and was pleased with the service from them
over 4 yrs. and probably 25-30k miles. Our current trailer has GYM's and also with no issues. So despite what I read about them the GYM's have also given good service. That's 2 years and maybe 20k miles. When I need new tires I'm still not sure which direction I'll go. I will consider LT but need to carefully look at the max. weights.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-29-2013, 05:45 PM   #8
2005 19' Safari
GLENDALE , AZ
See short summary of tire posts on this forum, below. Other forum members, please feel free to correct or amend, as necessary.
ST = Special Trailer
LT = Light Truck
XL = Extra Load
Options for original 15-inch wheels
* OEM Goodyear Marathon (GYM), ST tires, load range D (65 psi max). This is probably what came as standard equipment on your Airstream.
* Other brands of ST tires, load range D (65 psi max).
* GYM or other brands of ST tires, load range E (80 psi max), which have slightly higher load carrying capacity. A few common brand names include Maxxis, Carlisle and Tow-Master.
* Bias ply tires with specifications similar to ST tires. (These tires appear to be used mostly on much older Airstreams, which may have come with bias ply tires; and this substitution is not common on newer models.)
* Slightly oversized XL tires, with specs similar to old load range C (50 psi max). Typical size is 235/75x15. This substitution is relatively new; and there is very little history on their use. Also, the load carrying capacity of XL tires may be insufficient for some Airstream models.
Note: There are no LT tires made in size 225/75x15; so for 15-inch wheels, selection is limited to ST, XL and other tires listed above.
Options for 16-inch wheels
Some owners have switched to 16-inch wheels and LT tires, because they are very close in physical size and rating to the OEM 15-inch wheels and ST tires; and 225/75x16 is a common LT tire size that is widely available from many manufacturers.
Note: While it appears from anecdotal evidence that LT tires may be more reliable than similarly spec'd ST tires (especially for those who exceed the ST's 65 mph maximum speed rating), many AirForum members seem to be satisfied with GYMs and other ST tire brands (in 15-inch sizes).
The most common LT tire used is the 225/75x16, Michelin LTX M/S (or M/S2), load range E (80 psi max), which comes standard on Eddie Bauer models and is optional on several other Airstreams.
It appears that numerous AirForum members have switched to 16-inch wheels and tires, and there have been no reported failures that I can recall in the past year or two. However, there is no detailed data available to support this best-guess estimate.
A few AirForum members have switched to commercial-grade LT tires with steel sidewall plies (e.g., BF Goodrich Commercial T/A's and Michelin XPS Ribs). While these Airstream owners generally feel that commercial tires provide an additional margin of protection against tread separation and blowouts; these tires are significantly more expensive, and there is currently no supporting data to justify their use. However, it appears that owners using commercial tires feel that the additional confidence and peace of mind justifies the extra expense.
Additional reading:
http://www.airforums.com/forums/f438...res-16506.html
http://www.airforums.com/forums/f465...res-69297.html
http://www.airforums.com/forums/f438...oll-76867.html
Old 04-29-2013, 05:56 PM   #9
Central , Mississippi
I believe those of us that have 6 tires on the ground have an advantage...the weight per tire is low considering the mass of a 34' trailer. That make life for tires easier than, say, a 30' Slideout with 4 tires and about the same weight.
Knock wood, I've been happy with my Marathons.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-29-2013, 06:57 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Phoenix - if you go to a 15" ST E rated tire, how do you confirm whether the existing wheel can handle the higher pressure? My trailer's placard says the wheel is a 15x7jj but a google search on that doesn't produce info on tire pressure. Thx!
Old 04-29-2013, 09:08 PM   #11
2005 19' Safari
GLENDALE , AZ
Previous response to the same question in another thread:
The maximum pressure is molded into the aluminum on the inside of the wheel (visible when the tire is removed. I think the OEM 15-inch wheels say 110 psi, but not absolutely sure. In any case, 80 psi is OK. Also, for trailer applications, most tire stores, including Costco and Discount Tire, recommend inflating to maximum pressure that appears on sidewalls of tires, which is 65 psi for load range D and 80 psi for E's.
Old 04-29-2013, 09:21 PM   #12
W , New England
Thanks - not sure how I missed that... :-/
Old 04-30-2013, 04:19 AM   #13
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by Globie64 View Post
.......Isn't there some more or less simple answer?
Yes, but there isn't agreement on what that answer is.
CapriRacer is offline   Reply With Quote
Old 04-30-2013, 05:19 AM   #14
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
My opinion
Since you are asking for opinions, I'll give you mine.
In my opinion, the best 15" tire that would handle the weight of your trailer is the Michelin LTX M/S2 P 235/75/15XL. It is a "P" tire, so the weight rating on the sidewall must be derated when used on a trailer.
Have fun reading!
Lance
Top is offline   Reply With Quote
