Old 07-07-2009, 12:27 PM   #1
JackP's Avatar
1972 27' Overlander
New Haven , Connecticut
Which size replaces 7.00 x 15 load range C
I have a 72 overlander and the existing tires are 7.00 x 15 Load range C. (they look really old) I went to the local tire dealer and they can special order a Carlisle bias ply of the same size.
I called a local trailer dealer and they said they could match something up in a radial.
I was thinking that going with the radial would be a better choice especially if I'm traveling and need a replacement.
What size/brand radial have people used on this trailer?
Thanks.
Jack
JackP is offline   Reply With Quote
Old 07-07-2009, 12:31 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
ST or LT 2.25 75R15 are the usual choice. Some folks also go to a 16" tire.
Old 07-07-2009, 12:44 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Sorry, but would would be the advantage of the 16"?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-07-2009, 12:52 PM   #4
JackP's Avatar
1972 27' Overlander
Thanks for the quick response.
So have most people switched over to the radials?
I am I correct in thinking the radials will be an easier replacement if I have to buy one while traveling?
Jack
Old 07-07-2009, 02:54 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
I'm not sure that there is a significant advantage (I still have 15s). But a bigger rim has a different look especially with alloy rims. I know you can get a 16 with the same height as the 15s. But a higher profile will raise the coach a bit and will turn a bit slower.
Also to answer the original question a bit more I believe most owners have changed over to radials, and yes the radial would be easier to find on the road.
Old 07-07-2009, 04:22 PM   #6
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Yokohama makes a 700 x15 8ply they call it a 215 but it has 700x15 on the tire too. They are good tires.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-08-2009, 09:47 PM   #7
1963 19' Globetrotter
Moline , Illinois
Tire Rack has the Yokohamas in the 7:00x 15 size they are an LT radial tire and are excellent.
63air is offline   Reply With Quote
Old 07-09-2009, 05:19 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
7R-15 is how TireRack marks the YOKOHAMA RY-215
Yokohama
I ordered mine through DISCOUNT TIRE who mounted them and "Road Force" balanced them. I installed new lug nuts and CENTRAMATIC BALANCERS to accomodate un-balanced brake drums and installed to trailer at the parking lot.
This made a good combination which never ran hotter than 125F on a 105F Texas highway; just slightly cooler than the wears-like-iron Michelins on the truck.
After these, the GYM's look too soft across the sidewalls.
Old 07-09-2009, 07:07 PM   #9
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I replaced my 7x15 tires with Towmaster 7x15 D rated LT tires. Bought them at Discount Tire. One year later, very pleased with them.
Richard
Old 07-10-2009, 11:47 AM   #10
Thanks.
Jack
Jack.
The Airstream factory switched to radials many years ago.
To replace the 15 inch tires, they now use ST 225/75 R 15.
The load range you can use depends on what is on the wheels at this time.
What year and length is your Airstream?
Old 07-10-2009, 02:15 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
You should consider new wheels to go along with the radials...
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-10-2009, 02:41 PM   #12
purman's Avatar
1968 28' Ambassador
I also have these tires and like them too...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Load Range D or E? DFDureiko Tires 14 06-08-2009 08:48 PM
C load range spare dhe9 Tires 6 06-30-2008 10:57 AM
D or E load range? davidz71 Tires 16 04-09-2008 04:57 AM
Load range D or E? Bing-Bing Tires 5 05-30-2007 01:26 PM
Which Load Range sander17 Tires 27 05-04-2005 06:53 AM
