Old 01-03-2016, 08:15 PM   #1
quebec , quebec
Which brand and where to buy
I have hard times searching for white wall tires for my 59 overlander. Where can I found this here in canada or northeastern US? Which brand sells LT rated white wall tires? Thank you all
lephil is offline   Reply With Quote
Old 01-03-2016, 08:24 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
AFAIK, nobody. I have never seen a whitewall LT tire since the early 1980's, if then. I have seen white letter LT tires, but not white walls.
Old 01-03-2016, 08:25 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Try Coker Tire in Chattanooga, Tennessee. They specialize in tires for vintage automobiles. They have a lot of wide whites. They may have what you need.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 01-05-2016, 02:14 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Discount Tire has a WW in the brand called Hankook model H724.
Tire Details - Discount Tire
I have these tires on 3 classic cars with 15" rims. I asked Discount if they would be discontinuing this tire? They said not anytime soon. There is huge demand for this tire with some other application. If Hankook discontinues it Discount will look for another source as they can sell a lot of these.
Two issues.
1 the nearest store is Michigan or Ohio.
2 this is a passenger car tire and I wouldn't be excited about putting a passenger car tire on a trailer unless I used the trailer for show only.
>>>>>>>>>>>>>Action
Old 01-06-2016, 10:56 AM   #5
fth
2003 39' Land Yacht XL 330 hp w/2slides
Fairlawn , Virginia
Google "white wall inserts" for another option. They go on under the rim and work fine. They were used a lot when I was a kid 50+ years ago.
fth is offline   Reply With Quote
Old 01-06-2016, 10:57 AM   #6
fth
Fairlawn , Virginia
But then, so many things used to work just fine when I was a kid...
Old 01-06-2016, 11:39 AM   #7
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
I echo Action - Discount Tire. Make sure they jack the trailer up properly and while it's in the air check your bearings for any play.
kdickinson is offline   Reply With Quote
Old 01-06-2016, 12:59 PM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Are you going to tow the trailer much? Or just show tires?
Old 01-06-2016, 02:35 PM   #9
quebec , quebec
Of course I will tow more often the trailer than showing it off but I saw one of these trailer in SC with white wall tires and it was awesome. Many people on a VW forum wrote that tire inserts leads to tire problems so is this true on camping trailer??
Old 01-07-2016, 06:31 AM   #10
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You might check with Coker tires..
Old 01-07-2016, 10:00 AM   #11
1982 31' Excella
Missoula , Montana
I worked for Goodyear years ago and they always said almost all the sidewall failures occur on the white wall side of the tire, due to the extra rubber needed for white wall as it heats up more. The white lettering on race tires is put on with a grease pen.
Heat is what causes tire failure. I have not owned a white wall tire in over 45 years, and will continue with this practice, as my side wall failures have been 0.
Safe travels.
Vernbots is offline   Reply With Quote
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
Which brand rock guard to buy? 63air Rock Guards, Segment & Window Protectors 13 07-19-2006 09:21 AM
air conditioner- how big and which brand? gparker Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-14-2006 07:06 PM
