Old 08-22-2016, 09:01 PM   #15
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
"TURK123" mentions steel valve stems. I asked the CanAm people for metal valve stems to hold my NVision tire senders. I was told that they had none to fit the AS wheel and could find none. I didn't worry too much about it, as the sensors were very close to the wheel and just rested against the wheel when underway.
That is: until the monitor 'crapped-out' AGAIN. This time, big time.
I do not have kind thoughts about this TPMS. again.
Are there any TPMs that do work?
MelGoddard is offline   Reply With Quote
Old 08-22-2016, 09:05 PM   #16
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My TST system has worked for over 2 years as advertised. Nothing special about Airstream wheels. You should be able to find metal valve stems at any tire shop.
MICHAEL
Old 08-22-2016, 09:58 PM   #17
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We continue to be generally happy with our TST TPMS with the flow-through sensors and a repeater on the trailer. One cautionary note though: So far we've broken a couple of the sensors by banging them with (1) a torque wrench and (2) a curb. When that happens, it's quite easy to get a flat in no time because the sensor leaks air after it's been bent / broken. So, maybe next time we'll get internal sensors.
Rocinante is our 2014 International Signature 27FB
Old 08-23-2016, 05:25 AM   #18
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Our TST monitoring system works as advertised and glad we have it.
Originally Posted by Zigidachs View Post
The TST system monitors the psi and temp every TWO minutes. The sensor batteries on the 510 series, weigh 23 grams, last 5-7 years!
FAQs
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance shoes, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 08-23-2016, 07:00 AM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We purchased our new 2007 Safari SE 20 seven years ago and after reading about the high failure rate of its Good Year Marathon tires, we got a TPMS to "protect" us from their failure.
Two years later we traded for a 2012 FC 25 and realized if the GYM tires are the reliability problem, we should spend our money on better tires, not TPMS. Rather than buying another set of sensors for the TPMS, we put the money towards 16" wheels and Michelin tires. After selling the GYM's and 15" wheels, the upgrade cost us $1,000. Three years and we still have not added TPMS, and the issues they sometimes come with.
If your money is limited, I would recommend it be spent on high quality tires rather than TPMS to begin with, then decide if you really need trailer tire TPMS.
Doug and Cheryl
Old 08-23-2016, 07:47 AM   #20
Rivet Slave
Rocinante's Avatar
Per our post above, we disagree with that approach, preferring to add TPMS first, but glad it worked well for you.
Complete Rebuild of Electrical System worldinchaos Batteries, Univolts, Converters & Inverters 5 08-24-2011 09:16 AM
Black water flush system mjayjensen Waste Systems, Tanks & Totes 4 07-10-2011 05:21 PM
See-Level system installed crispyboy Waste Systems, Tanks & Totes 9 07-05-2011 05:45 PM
Suggestions for Home Theater System in Airstream FLMarine Audio, Video & TV 4 06-23-2011 08:10 PM
