Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 07-10-2015, 02:43 PM   #21
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Gnorts, I carry a 12 vdc compressor. It will run off the truck or the trailer batteries. I dont always have a generator along. My little compressor lives in the trailer and is always along.
It is a Viar 450P, had it for about 3 years now, and I am happy with it. It is was the only one I could find at the time that had a 100% duty cycle. It comes with everything you need and a nice bag to keep it all together in. I use it whenever I need to air up either the truck or the trailer. For me it is easier than using a portable 110v compressor.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
Alphonse is offline   Reply With Quote
Old 07-10-2015, 02:46 PM   #22
dznf0g's Avatar
Oswego , Illinois
I bought one of these a few years back:
Amazon.com: Q Industries MV50 SuperFlow High-Volume 12-Volt Air Compressor: Automotive
It's a pretty good little unit. No problem filling large tires. It doesn't see a heavy duty cycle, but has been used a dozen times or so. I made a few mods like. Longer power cord to reach trailer from truck battery while hitched up. Connector to match my solar pigtail in battery compartment. A few air hose mods to use a longer coiled line with fittings to match home compressor air appliances and a disconnect on the head for the airline.
-Rich-
Old 07-10-2015, 05:18 PM   #23
2018 25' Flying Cloud
Mission , Texas
I have TST on both spares as well as the AS tires.
ghamr is offline   Reply With Quote
Old 07-10-2015, 05:48 PM   #24
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I keep this in my tow vehicle, a Victor model 60135-8.
I also own a few different 12v compressors, but this is the best I have found
Alan
Old 07-11-2015, 12:26 PM   #25
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
My compressor: 3 gal. 1/3 HP 100 PSI Oilless Pancake Air Compressor
My generator: 3050-watt Chicago (Harbor Freight)
Both permanently reside in my TV. I even have 1/2 Ton Capacity Pickup Truck Crane mounted to lift out the generator (when I was younger I could lift out myself, but age crept up on me and I need the assistance of a device such as this crane).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 07-11-2015, 05:06 PM   #26
Vintage Kin
Fort Worth , Texas
Sure a nice setup!! Need that crane myself. No interest in pairing gensets so this'd work for just. one of sufficient size
Old 07-12-2015, 08:36 AM   #27
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
slowmover - they had a deal last winter at Harbor Freight - $99.00 all taxes in. I took the crane to my mechanic in Casa Grande, and it was installed for $60.
VE3JDZ
AIR 12148
WBCCI 8080
Old 07-12-2015, 06:10 PM   #28
Vintage Kin
Fort Worth , Texas
Thx. Was the crane installed / bolted to a big plate underneath, or?
Old 07-12-2015, 06:37 PM   #29
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have the same compressor for the road $39.95 on sale minus 20% w/coupon. I also have a compact 12volt for no AC power camping or side of the road.
MICHAEL
Old 07-23-2015, 12:15 PM   #30
2007 19' Bambi
Park City , Utah
Spare tire placement
When I was checking my spare tire pressure on my 2007 Bambi the tire is mounted with the valve up so I had to drop the tire to check the pressure. The spare on my TV is mounted the same way. Before I turn these over to make it easier to check pressures is there a reason for this? Is it a way to protect the valve from damage?
Chucke is offline   Reply With Quote
Old 07-23-2015, 01:17 PM   #31
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Originally Posted by AnnArborBob View Post
I have our spare on the TPMS so I check it everyday!
We do the same. This approach works for us too.
Old 07-24-2015, 07:56 AM   #32
2007 19' Bambi
Park City , Utah
Showing my ignorance here, what's a TPMS?
Old 07-24-2015, 07:58 AM   #33
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Tire Pressure Monitoring System!
Old 07-24-2015, 12:46 PM   #34
2007 19' Bambi
Park City , Utah
Old 07-24-2015, 09:15 PM   #35
Rocinante's Avatar
Here's one example. It's the one we use, though there are several other brands.
The sensors: TST 507 Flow Thru -
and the repeater: TST 507 Repeater -
Oh, and we bought an extra sensor so we could monitor the spare tire.
If we had it to do over again, we might have gone with internal sensors vs. these external ones.
Old 07-25-2015, 09:39 AM   #36
2007 19' Bambi
Park City , Utah
Tire pressures
For $300 I can still check the pressure manually. Thanks for the information thought.
Old 07-25-2015, 01:26 PM   #37
Rocinante's Avatar
Fair point, though it was only a few bucks for an extra sensor. We primarily use the TPMS to monitor our trailer tires while towing. That's another thread, though.
Oops, I should have checked the forum carver 1 Tires 11 12-26-2013 04:22 PM
Checked Baggage - Saddle - United Airlines? funkill Off Topic Forum 22 09-11-2010 09:24 AM
Finally checked out HULU Silvertwinkie Fun & Games 1 03-12-2009 07:43 AM
Has anyone checked out Trans-Americas? Dauntless On The Road... 5 08-05-2008 06:20 PM
Checked the Batt fuse lately? thecatsandi Tow Vehicles 14 11-26-2007 09:45 AM
