Old 07-09-2015, 10:37 AM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
When have you checked the pressure in your spare?
I was reading a thread on tires today and the dialogue had shifted to spares. I was reminded that I had not checked the pressure in mine for far too long. Yep, I have a compressor on board but messing with airing the spare up on the side of the road may increase my exposure time to the dangers of the traffic flying by.
How is the air in yours?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
Alphonse is offline   Reply With Quote
Old 07-09-2015, 10:50 AM   #2
dznf0g's Avatar
Oswego , Illinois
Checked last month
-Rich-
Old 07-09-2015, 11:14 AM   #3
Alphonse's Avatar
Lower Alabama , USA
Rich, you are a better man than me! But I am going to fix the problem as soon as I get over to the garage.
Alan
Air #64439
Old 07-09-2015, 11:26 AM   #4
2002 19' Bambi
Lafayette , California
Years ago I added a flexible braided wire valve-stem extension to our Bambi's spare. The end is held by a small cable tie in a place that is easily reached by my pump or gauge. Any time I check tire pressures, the spare is always included.
Tim
Tim A. is offline   Reply With Quote
Old 07-09-2015, 11:30 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
As part of my preflight checklist I check it before every trip. Valve is down so do not have to drop the rack to check.
MICHAEL
Old 07-09-2015, 11:32 AM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I have our spare on the TPMS so I check it everyday!
Bob Martel
WBCCI# 5766
Old 07-09-2015, 11:39 AM   #7
dznf0g's Avatar
Oswego , Illinois
Tim
I did too, this spring. Another forum member showed one (amazon or ebay...can't remember) about 2 feet long, so the valve is on the a-frame by the HAHA jack bracket.
-Rich-
Old 07-09-2015, 11:56 AM   #8
AWCHIEF's Avatar
Images: 33
I like that idea. Will have to check on getting another TST sender.
MICHAEL
Old 07-09-2015, 02:45 PM   #9
Alphonse's Avatar
Lower Alabama , USA
Tim
Here's a photo of one available through Amazon or Camping World. The SS braided one is for under chassis applications such as an Airstream. They also may one without the braid for the trunk of a car.
Name:	spare tire inflation hose.jpg
Alan
Air #64439
Old 07-09-2015, 02:47 PM   #10
dznf0g's Avatar
Oswego , Illinois
That looks like the one I ordered.
-Rich-
Old 07-09-2015, 03:22 PM   #11
Alphonse's Avatar
Lower Alabama , USA
Rich, how does it work? Meaning does it leak, was it okay to install, does the bracket hold the end well, . . . . ??
I have one on order now.
Alan
Air #64439
Old 07-09-2015, 03:39 PM   #12
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Checking the pressure is on my pre-trip check list. Though one of those extension hoses a good idea. It's getting harder for me to get under the trailer and truck. (gravity must be getting more forceful)
How about checking the spare in the tow vehicle. It's even more important.
Alan
Old 07-09-2015, 04:11 PM   #13
Alphonse's Avatar
Lower Alabama , USA
Originally Posted by A W Warn View Post
. . . . . . . How about checking the spare in the tow vehicle. It's even more important.
Alan, I am going to give you an Amen on that.
If the braided hose I ordered turns out to be of decent quality, I will fit one on the truck as well.
Alan
Air #64439
Old 07-09-2015, 06:46 PM   #14
2002 19' Bambi
The one your picture shows is identical to what I have. It has never leaked and installation was as simple as screwing it onto the tire valve. I did not use the bracket; a cable tie holds the end in place on the handle of the spare's bracket.
The extension has its own valve and holds the valve on the tire open.
Tim
Old 07-09-2015, 06:57 PM   #15
dznf0g's Avatar
Oswego , Illinois
As stated above. Holds air and I didn't use the bracket either. Zip ties only.
-Rich-
Old 07-09-2015, 07:55 PM   #16
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I don't normally check the pressure in my spares (TV or AS), but I always have a 3KW generator & an air compressor in the back of the truck. All my wheels have Dill TPMS sensors including the spares, so I could reset the system to see the spares as well, and would do so if I didn't have the generator & compressor at hand.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 07-10-2015, 10:15 AM   #17
1994 30' Excella
Livingston , Texas
Send a message via AIM to spclkaz
As someone above mentioned... checking the AP on the spares of both your TT and TV should be part of the pre-departure checklist (just like checking the AP in all the tires of the TT and TV as well before leaving.) That said, my TV is a pickup with an ARE Shell and I always carry a small air compressor I can plug in before departure to top off any tires that need it. (...and as a failsafe, I also carry a Honda 1000 generator with a little gas to power the compressor to air up the spare tires for fellow RVers broken down on the road as I have a couple of times over the 20+ years I have been traveling the highways of this great country.)
SPCLKAZ
94 30" Excella
99 GMC 3/4 Ton 6.0L
spclkaz is offline   Reply With Quote
Old 07-10-2015, 11:40 AM   #18
2015 27' FB International
mesquite , Texas
check every day when on the road along with extra spare in tow vehicle bed. first thing in morning before heading out. aircompress & generator must have items.never leave home without em!
moxie t. moto is offline   Reply With Quote
Old 07-10-2015, 02:04 PM   #19
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Before every trip, same time as I check the other tires. We've needed it too many times to forget about it.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-10-2015, 02:06 PM   #20
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
So, guys, tell me about the compressors you carry. I have the generator, and a compressor in the garage, but don't carry one with me on the road.
Yet.
Talk to me! I want it small and light weight. Have one for motorcycle touring, but it's way too small for the truck & trailer tires.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Oops, I should have checked the forum carver 1 Tires 11 12-26-2013 04:22 PM
Checked Baggage - Saddle - United Airlines? funkill Off Topic Forum 22 09-11-2010 09:24 AM
Finally checked out HULU Silvertwinkie Fun & Games 1 03-12-2009 07:43 AM
Has anyone checked out Trans-Americas? Dauntless On The Road... 5 08-05-2008 06:20 PM
Checked the Batt fuse lately? thecatsandi Tow Vehicles 14 11-26-2007 09:45 AM
