Old 06-03-2009, 07:15 AM   #1
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
When a good tire goes bad
I checked the INSIDE of my Michelin tires while repacking my bearings. This is what I found (not my tires, mine were made 08/07)
LTX-MS, 18 months old, 25,000 miles, made in Canada
Pulled all 4 and took them to Discount Tire. Michelin replaced 100%, Discount Tire covered mounting, bal, etc. Forum members, CHECK YOUR SIDEWALLS!
ArtStream is offline   Reply With Quote
Old 06-03-2009, 09:10 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Michael,
Good Find and horray for Michelin.
Just before heading east last fall I had my tires pulled and rotated. WE found one about to fail. A bubble had started on the inside of one the left side tires. The spare was mounted and Was on my way. Had we not done this I suspect the tire would have failed in the accident and the results would have been much different.
I have a much harder time switching to LT tires due to my Disc brakes. They are larger in diameter than the drum brakes.
Michelle TAC MT-0
Sarah, Snowball
Old 06-03-2009, 10:08 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Michelle
Please clarify. The diameter of the brakes should only effect the rim shape, the tires being beyond that.
If you already have 16 in. rims LT225 75 16 should work.
2004 Excursion 4x4
Old 06-03-2009, 10:15 AM   #4
HowieE's Avatar
Images: 12
Mike
I took a look. My Michelins LT 225 75 16 E were made in Germany and the sidewalls look brand new. They are at least 2 years old and have over 25,000 on them.
2004 Excursion 4x4
Old 06-03-2009, 10:35 AM   #5
Keymar , Maryland
Originally Posted by HowieE View Post
Michelle
Howie,
225/75R15 Load Range D
My understanding is from those who have done it. the 16 in rims have different setback from the hub. I would have to research on the forums and the net to find out which 16 inch rim would work. Additionally I would have to find load range E LT tires with a lower profile. Say a 65 or maybe 55.
I am on my third maybe forth set of Marathons. I've lost track. I keep them inflated to max pressure. Wear pattern is good and the temps are staying low.
Michelle TAC MT-0
Sarah, Snowball
Old 06-03-2009, 11:17 AM   #6
HowieE's Avatar
Images: 12
Originally Posted by thecatsandi View Post
Howie,
You might get in touch with
16" ALUMINUM TRAILER WHEELS FOR FIFTH WHEEL TRAVEL TRAILERS, TOWABLE RV'S, CARGO TRAILERS, HORSE TRAILERS, LIVESTOCK TRAILERS AND MORE
They had information on the offset when I changed, Mine have a -8mm offset but are on drum brakes. They are series #4 and are rated at 3960 lbs.
As for carrying MAX pressure in your tires please check that out against
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
I suspect you are overinflated and just hammering the trailer.
2004 Excursion 4x4
Old 06-03-2009, 11:52 AM   #7
Keymar , Maryland
Thanks for the wheel/rim info.
Factory says 65 PSI. I have tried 60PSI. I have tried lower pressures and the tires are wearing on the outsides and not in the middle. Only solution I know of, bump up the pressure.
Michelle TAC MT-0
Sarah, Snowball
cracking, michelin, sidewalls, tires
Is This Good, Or Is This Bad?? MuthaMustard Buyer Guidelines 7 05-25-2008 09:55 AM
The Bad , The Good and the Ugly- 2006 Classic thecatsandi 2006 - 2010 Classic (all lengths) 4 10-19-2006 03:56 PM
Tires good or bad? 72 Excella500 Tires 14 06-12-2004 03:16 PM
Take the good with the bad. Katt Doors & Locks 7 04-05-2004 10:32 PM
The good and bad TRAPEZE Airstream Motorhome Forums 1 01-01-2003 06:21 AM
