Old 07-10-2013, 03:39 PM   #1
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Wheel Chocks
Getting ready to purchase wheel chocks (rotochok). Do I need a pair or just one?
Thanks.
Tom
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 07-10-2013, 03:42 PM   #2
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
are those good'ns?
PharmGeek is offline   Reply With Quote
Old 07-10-2013, 03:49 PM   #3
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I did a search on wheel chocks. They appear to be the way to go. Just have to figure out if one will keep the trailer from rocking back and forth or whether a pair are needed.
Old 07-10-2013, 03:52 PM   #4
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
seems intuitive that two will be needed...one for each side? but im a rookie at this point...
Old 07-10-2013, 03:57 PM   #5
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I am inclined to agree but at $65 each I don't want to spend the money for two if one will do it.
Old 07-10-2013, 03:59 PM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Aren't the rotochocks the ones that sit between tandem tires on a side? I use regular chocks on the insides of one tandem (so under the inside of the left tire preventing it from moving toward the tow vehicle and under the inside of the right tire preventing it from moving toward the rear of the trailer). I believe the roto does the same thing only more conveniently and cooler looking :-)
I would suppose unless you're on an extreme angle, you need only one.
Old 07-10-2013, 03:59 PM   #7
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Have been using a single X-Chock on my double axle Tradewind for a few years with no problems.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
Old 07-10-2013, 04:52 PM   #8
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Maybe these? Save some dough????
Ok, maybe not...
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-10-2013, 05:08 PM   #9
r carl's Avatar
Lin , Ne
Four 2x4s or 4x4s 8" long will work just fine and can be had for free.
r carl is online now   Reply With Quote
Old 07-10-2013, 05:10 PM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Two chocks. One in front of a wheel, one behind the same wheel. The idea is, the trailer can't roll in either direction until you remove the chocks; to roll, the trailer would have to climb a chock and get over the hump first.
If you get two chocks that you can connect to each other with a short piece of rope or cable, that's best. Makes it harder to lose one. Most municipal airports use chocks like this to immobilize private planes.
Doesn't have to be anything fancy. I've seen wooden wedges cut out of a 4×4 post that work just as well as any plastic ones you can buy.
Also, if you have to use leveling blocks, chock a wheel that's on the ground, not one that's on the blocks.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-10-2013, 05:38 PM   #11
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Yeah, have always just chocked the tires with wedges fore and aft. Didn't know if rotochoks, or the like, would dramatically reduce the rocking of the trailer. Janet...that's the wedges I have...never used them in that way. Will give that a try!
Old 07-10-2013, 06:03 PM   #12
Janet H's Avatar
1964 26' Overlander
Images: 90
NO!!! That was supposed to be funny. Not safe.... not safe at all.....
Old 07-10-2013, 06:13 PM   #13
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I was being sarcastic...expect they would slide around a bit. :-)
Old 07-10-2013, 06:34 PM   #14
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Wheel chocks will prevent the trailer from rolling. One in front of a wheel and one behind as has been advised. They will not prevent it from rocking. That's the job of the stabilizers so after you get it leveled, chock the wheels to keep it in place then deploy your stabilizers to reduce or eliminate the rocking motion.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Who uses tandem wheel chocks? Splitrock Brakes & Brake Controllers 47 08-26-2014 09:20 PM
Fastway ONESTEP Wheel Chocks jcanavera Jacks, Stabilizers, Lifting and Leveling 5 10-03-2009 06:14 PM
Aluminum wheel chocks MW64OVERLANDER Jacks, Stabilizers, Lifting and Leveling 5 09-01-2008 09:58 PM
Wheel Chocks FordTruck Jacks, Stabilizers, Lifting and Leveling 42 04-18-2008 02:30 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
