Old 07-11-2013, 08:51 AM   #29
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I use chocks under each wheel to keep the trailer from moving fore/aft; one side chocked will allow it to swing dangerously sideways when unhitching if on a slope.
For longer stays I add the expandable chock/stabilizers between the tires which does a great deal to stabilize the trailer (in addition to the drop down stabilizers). The danger of the expandables without wheel chocks, is if on a slope during the night (for example) and you lost air pressure in a tire, that expandable chock would be loose and the trailer could swing sideways.
So the chocks under the wheel is necessary, the expandable chocks/stabilizers between tires is for comfort as well. I like both.
doug k
Old 07-11-2013, 09:14 AM   #30
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
I use a rotochok for each side. From my experience, especially when on inclines or declines, there would be lateral movement from the trailer, even if slight, during unhitching, and possibly during hitching. Chocks on both sides keeps everything in place. Just my experience.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 07-11-2013, 10:55 AM   #31
1976 31' Sovereign
Oswego , Illinois
I use semi truck trailer wheel chocks rubber w/chain connecting they are left over from trucking bus. If I had to pur. would probably be ones posted by Crispyboy
Old 07-11-2013, 11:12 AM   #32
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Originally Posted by Gilmurr View Post
I have the chocks from Hensley...
Right now they are $27.50 off at $35 each Here is the link.
They are fast and easy to use...no more mud and uneven ground surfaces to deal with, very secure....by the way I use 2 of them
Thanks for that - ordered two.
andreasduess is offline   Reply With Quote
Old 07-11-2013, 12:03 PM   #33
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by Protagonist View Post
Just goes to show, there's a first time for everything!
As my Poppa is fond of saying, "Even a blind hog finds an acorn once in a while."
My reply was "yessir, but he still has to root around a bit!"
And that's how I got these new teeth.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 07-11-2013, 12:09 PM   #34
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Like A W Warn, I have two of those but they don't fit and the nuts are corroded so badly it is like they are welded. Can't adjust them. Thanks for the link though. Will contact those folks. They used to make an extender that bolted to the pad to make them fit. Mine came with my A/S when I bought it many moons ago.
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 07-11-2013, 05:15 PM   #35
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I dropped Deb an email this morning. She already responded. She said they have sizes to fit different wheel spacing, so I have to wait a day or to two for measurement. I will be getting at least one new one, maybe two. I have my wheels off doing a wheel bearing grease job right now.
If I already had two, like you do, I think I would re-work them. I have been thinking about adding a piece of tire tread to widen the friction points. I think a half inch added on each side would make mine work.
Alan
A W Warn is online now   Reply With Quote
Old 07-11-2013, 05:46 PM   #36
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I went to Rotochocks about a year ago and never looked back. They are byfar the best investment I've made for my AS in a long time. Not only do they work super easy, but you can put a padlock on them for added security. I have 2 but only lock one. I definately recommend them, and buy a pair.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is online now   Reply With Quote
Old 07-11-2013, 06:32 PM   #37
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Alan...emailed her as well. Sent her my tire measurements. Waiting for a price. Got some thinking to do on what way to go. Those or rotochoks. I really like the idea of supporting a family owned business that owns an Airstream.
Tom
Old 07-11-2013, 07:38 PM   #38
urnmor's Avatar
Berlin , Maryland
Are the rotochoks for stabilization to prevent rocking or is the purpose to keep the AS from moving backwards or forwards.
John
urnmor is offline   Reply With Quote
Old 07-11-2013, 07:45 PM   #39
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Both for my purpose.
Old 07-11-2013, 08:47 PM   #40
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
A couple of people have mentioned less expensive options.
Here are a couple that I spotted at the first Branson rally back in 2007:
Vaughan
Old 07-11-2013, 09:24 PM   #41
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
The bottom pic looks easy and cheap. Like it.
Old 07-11-2013, 09:39 PM   #42
reinergirl's Avatar
Hollis , New Hampshire
Yes! And far less likely to be nicked! The "between the tire" chocks worry me, you forget ONCE and it seems to me you'd have major damage, the others ...well driving over a chock wouldn't be good but not awful. Anyone here drive away with a between the wheel chock? What was the damage?
reinergirl is offline   Reply With Quote
Who uses tandem wheel chocks? Splitrock Brakes & Brake Controllers 47 08-26-2014 09:20 PM
Fastway ONESTEP Wheel Chocks jcanavera Jacks, Stabilizers, Lifting and Leveling 5 10-03-2009 06:14 PM
Aluminum wheel chocks MW64OVERLANDER Jacks, Stabilizers, Lifting and Leveling 5 09-01-2008 09:58 PM
Wheel Chocks FordTruck Jacks, Stabilizers, Lifting and Leveling 42 04-18-2008 02:30 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
