Old 07-11-2013, 06:04 AM   #15
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
I use BAL X-chocks on each set of wheels. Easy to use and store. They work great.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 07-11-2013, 06:22 AM   #16
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
I have the chocks from Hensley...
Right now they are $27.50 off at $35 each Here is the link.
Ultimate Tire Chocks
They are fast and easy to use...no more mud and uneven ground surfaces to deal with, very secure....by the way I use 2 of them
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 07-11-2013, 06:34 AM   #17
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I have used Rotochoks for several years and been very happy with them. I use two pairs, one for each side. Quick to put on and remove. I can't say the eliminate trailer rock but sure seem to reduce it. I only use one chock when in storage.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 07-11-2013, 06:44 AM   #18
aftermath's Avatar
Spokane , Washington
The SOB that I owned had quite a bit of movement when set up. The stabilizers were down but it still rocked a bit when set up. I looked into getting some roto chocks but never did. My cousin has an Arctic Fox that is the most solid feeling trailer I have ever spent time in. My Airstream is somewhere in between.
I think this has everything to do with the construction and the weight of the trailer. The Arctic Fox is heavy when compared to my 25FB and it has a very sturdy frame under it.
I use the yellow plastic chocks and am happy with them. They are light, inexpensive and easy to store. Can't see spending money to fix a problem that really isn't a problem for us. I have heard that the ones you are looking at do add a degree of stability when you are set up. I sort of liked the Hensley ones posted earlier.
aftermath is offline   Reply With Quote
Old 07-11-2013, 07:05 AM   #19
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I like the traditional wheel chocks. You NEED 2 of them. Most of the time I only use one if the site is relatively level but if there is any real incline put on two. They take away any rocking of the trailer, they can be locked and are quick and simple to install/remove - no tools needed. I had the Hensley (BAL) chock but sold them after getting these.
They are manufactured by a family in Angola, Indiana. Her name is Deb and you can email her at parttimerunner1@aol.com. They come in various sizes. I just bought another pair back in June for $55 each in the largest size.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 07-11-2013, 07:18 AM   #20
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
crispboy....i am totally confused...how do those work?? ill use cheapey ones for a while....money tree runnin' low
PharmGeek is offline   Reply With Quote
Old 07-11-2013, 07:21 AM   #21
dznf0g's Avatar
Oswego , Illinois
I have used only one of these (not both sides) since 1993. Very durable and works well.
-Rich-
Old 07-11-2013, 07:42 AM   #22
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I'm not crispboy, so apologies for stealing his thunder, but as an engineer I can't resist anwering "how" questions…
The operating mechanism appears to be a cam-action lever and a turnbuckle. Gross adjustment with the turnbuckle, so the chock is just loose enough to get on and off, then use the lever to tighten. If the side with the threaded rod faces up, then lever up = loose, lever down = tight. Which is the way I'd use it; that works better ergonomically than the other way around.
As long as they're always used on the same trailer, you'd only need to adjust the turnbuckle once. Operation is quick and easy thereafter, just a flick of the lever to install or remove.
I can't tell from the photo, but if there's an eye in that tab sticking up by the lever handle on the left side of the photo, it would be possible to use a padlock to lock them closed, so it would work like booting the tires, too, for storage.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-11-2013, 07:47 AM   #23
dznf0g's Avatar
Oswego , Illinois
Protag is exactly correct....and yes mine does have provisions for a padlock.
-Rich-
Old 07-11-2013, 07:49 AM   #24
Just goes to show, there's a first time for everything!
WBCCI #1105
TAC LA-4
Old 07-11-2013, 07:59 AM   #25
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
And to close the loop, since Protagonist explained how the mechanism works... they go between the tires on a tandem-axle trailer in similar fashion to the Hensley chocks in post #16 and to X-Chocks or the knock-off X-chocks I have.
I've been happy with mine, though I paid considerably less than what they cost at Camping World at the moment.
Deluxe Chock & Lock twin pack
— David
Old 07-11-2013, 08:16 AM   #26
crispyboy's Avatar
1994 30' Excella
Protagonist is exactly correct in the way the mechanism works.
The only thing different is that I sometime adjust the nut a little differently depending on the severity of the slope.
They do come in different sizes. The manufacturer will want to know the distance between the tandem wheels. The measurement for our trailer was approximately 5 inches.
WBCCI # 3072
Old 07-11-2013, 08:19 AM   #27
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I use the less expensive ones from Hensley (two) and have been happy with them.
In our case, a big plus compared to standard chocks under the tire is that when we go to pick up our trailer from storage in February here in the frozen north, they are not frozen to the ground! I have experienced that with the plastic chocks and pretty much had to destroy them, knocking them out from under the wheels with the back side of an axe!
About the only concern I have with the Hensley ones is that they are effectively scissors jacks on their side and would be capable of putting considerable force trying to push the two wheels apart.
I have wondered if it would be possible to actually misalign the axles by cranking them up too hard - so I try not to do that!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-11-2013, 08:25 AM   #28
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have one of those now, since the second has disappeared. I was looking for a source online just yesterday. I used them on my 73, 78, and 99 model Airstreams, but the one I have will not work on my Safari. The wheels on the Safari are to far apart at the tightest adjustment. Thanks for the email address! Does anyone know if they come in different sizes?
Alan
A W Warn is online now   Reply With Quote
Who uses tandem wheel chocks? Splitrock Brakes & Brake Controllers 47 08-26-2014 09:20 PM
Fastway ONESTEP Wheel Chocks jcanavera Jacks, Stabilizers, Lifting and Leveling 5 10-03-2009 06:14 PM
Aluminum wheel chocks MW64OVERLANDER Jacks, Stabilizers, Lifting and Leveling 5 09-01-2008 09:58 PM
Wheel Chocks FordTruck Jacks, Stabilizers, Lifting and Leveling 42 04-18-2008 02:30 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
