Old 06-01-2006, 05:26 PM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
What would be the best tire's for my trailer?
7.00x15 is the size not sure what ply or if you can go radial?
which would the best for a decent price?
Mrcrowley is offline   Reply With Quote
Old 06-02-2006, 10:46 AM   #2
Use what Airstream has used for many years.
Goodyear Marathons, load range C or D.
If your wheels had "C" tires on them for an extended period of time, you must not change the ply to a "D".
To do so will cause the old wheels to split around the circumferance.
Tires for an Airstream trailer should "NOT EVER" be chosen because of price.
Use what is known to perform properly, for thousands of users, not just a couple of users.
"D" tires should be on a 31 foot Airstream, never more.
Use ST225/75 R15 load range "D".
Old 06-02-2006, 04:49 PM   #3
1966 17' Caravel
Seattle , Washington
Send a message via AIM to kitchenclose
Here's my thread for tires on a Caravel. Hope this helps. I'm getting the Marathon tires which were recommended.
http://www.airforums.com/forum...=caravel+tires
Good luck
K
kitchenclose is offline   Reply With Quote
Old 06-02-2006, 08:48 PM   #4
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
does anyone know of a good brand of tire for the 700 X 15 ??? (like goodyear,michelin ect,,,,)
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 06-02-2006, 10:19 PM   #5
Frank S
peoria , Illinois
Hi scf31--WalMart has Goodyear "Work Horse Rib", Bias Construction 7.00-15LT D rated 2045# @ 65psi, 29.8"OD/8.3"wide, for $107.20. They are special order from the trailer tire section of the catalogs they have by the tire display.--Frank S
Frank S is offline   Reply With Quote
Old 06-03-2006, 01:46 AM   #6
1960 24' Tradewind
santa barbara , California
Yes the goodyear workhorse rib is a very good tire for the 700-15.I use herculese 700-15 on my 60 tradewind and they have worked great for 3500 miles so far .I also like the vintage look they give the coach.There are many choices out there for tires.Greenball tire also has 700-15 tires called towmasters,I have used those before the hercules ,they were c range ,not the right load rating. I put new wheels on it with the D rated herculese tires
so no wheel troubles there.
Scott
scottanlily is offline   Reply With Quote
Old 06-06-2006, 08:57 PM   #7
1963 19' Globetrotter
Moline , Illinois
Have had great luck with Yokohama (Model# RY215) on my '63 Globetrotter. They are a radial but have a vintage look. Got mine at tirerack.com. Good price great service.
63air is offline   Reply With Quote
Old 06-08-2006, 05:23 PM   #8
1984 31' Excella
Norfolk , Virginia
Images: 11
tires
Check the specs.
What is the speed rating?
Remember, according to Goodyear's own chart there Marathon is only good to 65 MPH on road surfaces 100 Degrees or less.
Any faster ever or any hotter ever will damage the tire. Thats all the marathon is tested and certified to.
Anyone ever find a road in the summer time in the south 100 degrees f or less?
Read this forum
http://www.airforums.com/forum...res-16506.html
Beginner is offline   Reply With Quote
Old 06-08-2006, 08:46 PM   #9
1990 32' Excella
jonesboro , Arkansas
Tires ?????
I will probably start a war with this but .Firestone has a tire that is called a lemans. The at 235-75-r15 is the same as the bridgestone dueler.I tried them on the advice of my firestone dealer with great results. He said airstreams do not have the problems with top heavy sway that box and fifth wheels have. This means they don't need the stiffer side walls the others do.I put 15,000 miles and 3 years on the ones I had on my 73 31". I have 25,000 miles and 2
&1/2 years on my 86 31" without 1 flat or blowout,this includes several trips thru the rockies.I have pulled 200 miles thru the ozarks with a cup of water on the counter that did not move. The tires are 6ply load range D. I know everyone has an opinion about tires,so I put mine in too.
joel is offline   Reply With Quote
Old 06-09-2006, 11:27 AM   #10
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
In Phoenix from late May to labor day the high temp for the day is 100 or higher. With some exceptions usually that is a period of 100+ days of over 100 degrees. The outside temp gets to the 100 degree mark at about 10AM and stays there until 5 or 6PM. The pavement, well that is a little different. I am sure it gets to way over 100. Likely 10 to 15 degrees hotter that the ambient air. So that can be 120 to 130. And Phoenix is not the hottest place in AZ.
(Well it is, just not in temps )
>>>>>>>>>>>>>>>>>>>>Action
Old 06-09-2006, 11:47 AM   #11
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
Goodyear Marathons
This is just a suggestion:
Tire Rack has Goodyear Marathon Special Trailer tires on sale for $76.00 ea size 225/75x15 Load range 'C', Load range 'D' are $84.00ea. I hope the link works (it does!!) as searching for trailer tires is rather difficult on their site.
They ship quickly and would ship to your dealer. He won't make any profit from his house brand, but you won't be buying an unknown quality tire. I've 6 marathons on my 34' and they are working fine. I'm sure there are other trailer specific tires out there, so take a little extea time to get a proper pair of 'shoes' on your bauxite beauty!
Hope this helps,
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 06-09-2006, 06:40 PM   #12
scf31's Avatar
1977 25' Caravanner
So many choices out there,,,,,,
Old 06-10-2006, 05:34 AM   #13
1984 31' Excella
Norfolk , Virginia
Images: 11
joel
As we noticed in the past responses, the LT tires seem to hold up better than the ST tires.
You neglected to state whether the tire was a P metric radial or a LT tire.
At any rate nothing in this size carried a speed rating according to the Firestone web site.
http://www.lemanstire.com/tires/catalog/lemans-at.jsp
I don't know what unit you have these on, but for my unit I stayed with the 225/75 because of the tire outside dimentions/wheel well clearance.
Keep us posted.
Old 06-10-2006, 07:56 AM   #14
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
>>>>>>>>>>>>>>>>>>>>Action
Action, The way I figure it the road temp hits 100 around the 1st of May and drops below in October. Two years ago I was in Parker in a company truck. I had just driven out of the desert near Bouse and noticed a rear tire going flat on the burb. I pulled over and when I went to jack it up, the jack sank in the blacktop! I had to move to a cement area to change the tire. It was about 120 degrees that day. BTW, what do you have on your trailer. I have 7.00 x 15 bias.
Richard
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Trailer wiring & new trucks 3Ms75Argosy On The Road... 6 11-09-2002 09:45 PM
New trailer, old club rally Pahaska Other Rallies & Events 7 07-24-2002 01:26 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
