Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 06-26-2007, 02:19 PM   #1
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
What tire to replace Tow Masters
I have long used Tow Master ST 225 75 15 tires on my trialer with vry good results but they have now moved the molds to China. Since I am not interested in joining the Class Action Law Suit against Chinese tires what is a good replacement?
I am not interesed in up sizing the wheels at this point so comments should be kept to 15 in wheels.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 06-26-2007, 03:15 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
Are the Towmasters radials or bias, and do you have a preference?
Non-contributing deadbeat.
Old 06-26-2007, 03:47 PM   #3
HowieE
HowieE's Avatar
Images: 11
Radials. I suspect Bias belts would not last lomg on a tri axle. The rear radial takes a beating as is.
Old 06-26-2007, 04:18 PM   #4
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 18
Hold on there!
Where did you hear that Towmasters were now Chinese?
I realize that if you visit Toronto or Vancouver you may think its China....but, Towmaster remains Canadian....as far as I know. I use 'em, and I like 'em.
Old 06-26-2007, 04:51 PM   #5
HowieE
HowieE's Avatar
Images: 11
I needed a tire last Feb while on the road and called Greeball the distributor for a local stocking dealer. They told me the molds had been shipped from Canada to China. When I called today they confirmed that the only tires now available were from China.
Old 06-26-2007, 04:54 PM   #6
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
It's entirely possible. Everthing is moving to China...
Old 06-26-2007, 05:51 PM   #7
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
WOW guess I got 4 of the last "Great White North" Tow Masters. 2 months ago. Hey nice Kayak Howie! DG
In any firefight,
nobody cares what you did yesterday,
or what you may do tomorrow.
The only thing that matters
is what you are doing
right now.
Proud Appellation American
doorgunner is offline   Reply With Quote
Old 06-26-2007, 07:24 PM   #8
Beginner
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Replacment Tires
Try a set of Cooper Custom Trailer Plus tires.
If you can find them, they should work well.
Beginner
Beginner is offline   Reply With Quote
Old 06-26-2007, 08:04 PM   #9
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
My first 2 sets of tires were Canadian Tow Masters, and I got 40,000 miles out of each set. Very good wear, very satisfied.
I now have 15,000 on Canadian Marathons.
I don't no what I'll do next?
Michael
ArtStream is offline   Reply With Quote
Old 06-26-2007, 10:10 PM   #10
georgezink
Profile:  1977 Argosy Minuet 6.0 Metre
1963 19' Globetrotter
Lawrenceville , Georgia
First post
Just purchased Cooper Custom Trailer Plus ST225/75R15 from TireSavings.com. They are due to arrive on Thursday. Couldn't find them locally. They are rated for 2540# (load range D) and speed rated to 112mph. Most ST tires are only rated for 65mph -- didn't want to take the chance. Hope they work out, 'cause they're not cheap. Geo...
flcracker
georgezink is offline   Reply With Quote
Old 06-26-2007, 10:15 PM   #11
Beginner
Norfolk , Virginia
Images: 11
Replacment Tires
gerogezink
Keep up posted. The specs on those tires were impressive.
The main reasons I went with the Commercial T/As and 16 inch wheels was the availability and the fact that Goodrich is owned outright by Michelin and those tires are now made by Michelin. But it was costly.
Beginner
Low Tire Detector Pahaska Tires 31 12-19-2007 05:58 PM
Tire Pressure TBYRNE Tires 11 08-09-2002 10:04 PM
Flat tire detector Pahaska Tires 6 08-08-2002 07:38 PM
Tire code info FrankR Tires 1 05-20-2002 10:18 AM
What tires to replace with? Charcigar Tires 1 04-09-2002 02:08 PM
