Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 08-29-2007, 07:41 PM   #1
mgordon's Avatar
Profile:  1974 31' Sovereign
Magnolia , Texas
How do I know what kind of tire to I need to tell my husband to get. Is there anywhere that says 1974 needs X kind of a tire with X pattern?
Thanks.
Michele Gordon
mgordon is offline   Reply With Quote
Old 08-29-2007, 10:03 PM   #2
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Revisit..
Steve. The bolt pattern is 6 hole on a 5 1/2 bolt circle. Also they need to be with an 1/2 inch inset. Read our article on "Junk Yard wheels" that in our web site. The same thing happens when wheels are under rated.Andy
Michele,
The specifications Andy posted should be the same for your Airstream.(it's in the same age group.) For the tires, you may or may not have a difficult time finding the 7.00x15 that were used originally. Just be sure you ask for a tire rated for trailers and, within the proper weight range. On the newer tires, look for "ST" stamped on the side-wall. Please don't use a LT and or PASSENGER CAR TIRES on your trailer..
I hope this answered your concerns.
53FC
53flyingcloud is offline   Reply With Quote
Tire PSI? ldetsf Tires 9 11-10-2006 09:18 AM
Tire age and the DOT SafeHarbor Tires 3 08-27-2006 06:35 PM
Tire ? Stream 1529 Tires 8 08-04-2006 11:55 AM
tire age? Zeppelinium Tires 2 05-04-2006 08:52 PM
What is behind my tire? jkenny Axles 6 01-21-2004 02:21 PM
