Old 01-06-2004, 06:48 PM   #1
Whistling_Gypsy
Guest
Posts: n/a
what size tires? please respond within 22 hours and 46 min.....
I was thinking of bidding on these tire covers for my 73 sovereign: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2451857264
They are for 14-15" rims....
Unfortunately, I am a few hundred miles away from it (the AS, not the covers) and I can't check the tire size. Does anyone know if these will fit??
Thank you.
Old 01-06-2004, 08:56 PM   #2
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Since you haven't had a reply yet,
Your trailer appears to be a 29-31ft unit?
If you have radial tires on it they are probably ST225/75r15 and if they are bias they are probably 700-15. My literature says the following--
ST225/75r15 at 28.3" outside dia.
700-15 at 29.2-29.5" outside dia.
The welting on those covers are following the sw/tread line around the tire so they appear to fit exactly what the seller refers to as a ST225/75r15.
If the ebay seller is correct on the size (st225/75r15), then they should fit if you have relatively new radial tires.
Is any one home to look at the size?
wingfoot321 is offline   Reply With Quote
Old 01-06-2004, 11:08 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Sorry I can't help you with the tire size/fit...but I looked at the ebay link referenced and it appears that the seller has several of these listed and most have a "Buy it Now" option for only a couple of dollars more...just in case you miss the one closing so soon.
Hang in there...someone should be able to help out ~
Shari
Old 01-07-2004, 06:57 AM   #4
I have a 31 foot, 1973 Soverign International. My tire size is
7.00 R 15 LT.
Hope this helps.
Dick
Navigator is offline   Reply With Quote
Old 01-07-2004, 04:23 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Those tire covers should work just fine for your Soverign.
>>>>>>>>>>>>>>>>>>Action
Old 01-07-2004, 04:31 PM   #6
Whistling_Gypsy
Guest
Posts: n/a
I think I'll give those a try then. Thanks very much for your help. Only 3 weeks left 'till I'm fulltiming it! Geesh, time sure flies when you have a million things to do.
