Old 03-01-2008, 11:25 AM   #1
Rot-Roo Rastro!!
silversled's Avatar
2000 30' Limited
What PSI should I have my tires?
My owners have Goodyear Marthon ST225/75R15 RATED D as in dog. I told them that I did not like the Marthon for my silver dog house. They are wondering what should we set the PSI? It gets hot down here in Texas so if we set them at 65psi cold, it should run them up to 100psi on a hot summer day.. What do any of you folks recommend.
Thank you,
Astro
Astro & the humans I train Barry&Andrea
2000 Airstream Limited 30' ~ Silversled
2005 Ford Powerstroke, 4X4, Crew Cab
AIR #12075
silversled is offline   Reply With Quote
Old 03-01-2008, 12:18 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Fill them to 65 PSI cold and don't worry about it. Truckers have told me that slightly more pressure is better than not enough. Most tire failures are due to not enough pressure.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-01-2008, 01:10 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by silversled
My owners have Goodyear Marathon ST225/75R15 RATED D as in dog. I told them that I did not like the Marathon for my silver dog house. They are wondering what should we set the PSI? It gets hot down here in Texas so if we set them at 65psi cold, it should run them up to 100psi on a hot summer day.. What do any of you folks recommend.
Thank you,
Astro
65 cold or what it has on the plate on the side of your trailer.
35PSI rise would be a a 350 degree or there abouts temp rise. Your tires would be getting soft by then.
Michelle TAC MT-0
Sarah, Snowball
Old 03-01-2008, 03:52 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up What they said...
And if high tire temps are a concern down there in Texas you might
consider one of these.
Also come in handy checking wheel bearings, you'll be surprised what it can
be used for, just don't ask my co-pilot.
Micro Temp Infared Non-Contact Temperature Gauge MTEXP Pistol Grip Laser Temperature Gauge Backlit LCD Display-Best Computer Online Store Houston Buy Discount Prices Texas-Directron.com
This is a good "tire gauge"..
Psiclops : Tire Pressure Gauge Equalizer, from Equal-Air Inc.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-01-2008, 03:57 PM   #5
1984 31' Excella
Norfolk , Virginia
Images: 11
Tire Pressure
I recommend that you purchase a Tire Pressure Monitering System because on a double axle trailer you cannot tel when a tire goes flat. You find it when you stop of a passing motorist is pointing at your trailer.
They are a real vacation saver.
Beginner
Beginner is offline   Reply With Quote
Old 03-02-2008, 05:52 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Silver sled, it gets hot in AZ too. Likely hotter than TX on the asphalt. When towing I run all my tires at max inflation cold. TV and trailer. I have had zero issues with the tires in the heat of the day, as long as they are not old or worn to the wear bars.
This also means that I check my tires frequently because the temp variation between summer and winter.
>>>>>>>>>>>>>>>>>Action
Old 03-02-2008, 09:01 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We run our Bambi at the recommended 65 psi cold...and installed PressurePros in December...so far we have risen to a steady 71 psi after towing on the highway...at least in the winter months...it will be interesting to see how high it gets in the summer. I would think the increase in psi after driving is taken into consideration on recommended cold pressures.
TB & Greg and Abbey Schnauzer
#3954
Old 03-03-2008, 12:05 AM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Astro. Tell your owner to keep the trailer tires set at 65 lbs cold as per Airstream owner's manual. Your trailer is quite a bit heavier than mine, so I certainly wouldn't run less. I haven't been anywhere cold yet, but I've driven in plenty of 100 degree plus weather. [California, Nevada, Arizona, and Utah] No problems so far.
One more thing Astro; Tell your owners that if their trailer still has the original tires, it's time to change them no matter what they look like. [age between 5 and 7 years old need to be replaced.]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
Tire PSI? ldetsf Tires 9 11-10-2006 08:18 AM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
Tires 74Argosy24MH Mechanics Corner - Engines, Transmission & More... 3 09-10-2003 08:32 AM
Shurflo regulator_50 psi is not 40 femuse Water Heaters, Filters & Pumps 6 03-28-2003 09:54 AM
