Old 07-28-2014, 02:39 PM   #1
thunderbird's Avatar
1968 26' Overlander
Spijkenisse , netherlands
What psi?
I used to have the orignal size tires 7.00 / 15 with the correct pressure of 50psi
but as i could not get them here in holland ,I had to settle for the next best
and that was 8.40 / 15 and they are 10 ply .
now what is the best tire pressure for these tires ?
the trailer weighs about 2.3 tons
26 foot overlander from 1968.
regards George
thunderbird is offline   Reply With Quote
Old 07-28-2014, 02:41 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Check the ratings of the tires and recommended pressure by tire manufacturer.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 07-28-2014, 02:59 PM   #3
1968 26' Overlander
they are made in bulgaria
manufacture unknown
Old 07-29-2014, 05:29 AM   #4
CapriRacer
CapriRacer's Avatar
I'm in the , US
I have tire standards manuals for the US, Europe and Japan. A 7.00-15LT is listed in the US and Japanese manuals, but not the European manual. But none of them list an 8.40-15.
There is very likely some loading information on the sidewall along with the maximum inflation pressure. Would you please look at the tire and tell us EXACTLY what it says. It ought to be in the form of "Max Load XXXX Lbs at YY psi."
Also look to see if it has a load index. That should look like "XXX/YYY" followed by a letter.
CapriRacer is offline   Reply With Quote
Old 07-31-2014, 02:47 PM   #5
1968 26' Overlander
Okay I will check what's on the tire
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi Driver1 Tires 3 06-23-2008 08:26 PM
What PSI should I have my tires? silversled Tires 7 03-03-2008 12:05 AM
Tire PSI? ldetsf Tires 9 11-10-2006 08:18 AM
Shurflo regulator_50 psi is not 40 femuse Water Heaters, Filters & Pumps 6 03-28-2003 09:54 AM
