Old 10-24-2014, 10:18 AM   #99
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
That US regulation might not apply in Canada.
Old 10-24-2014, 10:54 AM   #100
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
No problem. I'm more interested in thoughtful guidelines than regulations.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-25-2014, 10:35 AM   #101
Ravenna , Ohio
As I recall the Canadian regulations basically point to US DOT (NHTSA) regulations which uses the US Tire & Rim Association published Load Inflation numbers.
With very few exceptions all the major tire companies follow US TRA tables. The few exceptions are usually based on a metric size tire originally developed in Europe being "converted" to a TRA size application.
I recall only running into a handful (3 to 5) such examples.
Retired tire engineer (40 years). Write a blog on RV tires.
Tireman9 is offline   Reply With Quote
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Tire pressure with T03s and Michelin LTX dsaxon22 Tires 27 02-04-2014 06:11 AM
Do you tow in "use" or "store"? xo1rider 2011 - 2015 International 17 11-06-2011 09:20 AM
Newbie electrical questions -- "Use" and "Store"? jjboone101 Batteries, Univolts, Converters & Inverters 8 08-27-2009 09:44 PM
