Old 10-22-2014, 11:43 AM   #85
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
The link you provided is helpful re: the 16 inch Michelins. Thanks.
Too bad they don't list the 15 inch LTXs. Though they are still available, I guess their days are numbered.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-22-2014, 12:12 PM   #86
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Here is the latest issue:
Michelin Truck Tire Data Book
On the blue menu bar at the top of the document, there is a pdf symbol that will let you download a page or the entire menu.
I downloaded it for my own use, but it is too large of a file to upload here. It is 13.4MB.
I wonder, if you searched for earlier versions you could find one that has the 15 inch tires.
Ken
Old 10-22-2014, 01:46 PM   #87
TinTin's Avatar
Canmore , Alberta
I pick up my tires tomorrow. Another member let me know by PM that maximum inflation on the 15 inch LT23575R15 is 50 psi (1985 lbs). A much simpler inflatory decision than that of the 16 inch version.
Bob and Nancy
Old 10-22-2014, 03:55 PM   #88
Ag&Au's Avatar
I apologize for not posting that. I thought you knew that and just wanted to see a load/pressure table. I ran across that 50 Psi figure by searching for LT23575R15 . One of the the results was the specs.
Anyway, I'm sure you will be pleased with the tires.
Ken
Old 10-22-2014, 07:03 PM   #89
TinTin's Avatar
Canmore , Alberta
I like my numbers simple, 50 psi and 110 ft lbs torque for the 15 inch Michy setup. Same numbers used for the 14 inch GYMs.
Bob and Nancy
Old 10-22-2014, 08:05 PM   #90
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Thanks TinTin, good report on a 15" "Michy" setup. We need more of this, what works for you on your Airstream.
Doug and Cheryl
Old 10-23-2014, 04:55 AM   #91
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When we installed the 15" Michelins on the factory 15" rims on the 2013 25FB International Serenity that had a GVW of 7,300 pounds, the scales reported that the trailer axles were loaded sub 6,000 pounds camping ready.
The 15" LTX (P) 235/75R15 XL Michelins have a side wall rating of 2,183 pounds but must be derated to a capacity for trailer use of 1,985 pounds (see 49 CFR 571.110 below) at 50 psi which is the maximum air pressure per the tire sidewall. That means the four tires can support a total load of 7,940 pounds. That is at least a 25% load safety margin with better and wider tread for improved braking and the bonus of softer ride for the trailer.
If I remember correctly, Andy at CanAm suggested 44 psi for our trailer. I did not see any issues, but carried 44 to 46 psi as the analog tire pressure gage had 2 psi increments. When I started using a racing quality digital gage, the I set the pressure to the 45 psi and knew it was plus or minus 0.5 psi of that number.
The last trip with the Classic, I set the 16" LT225/75R16/E LTX M/S2 Michelin tires at 75 psi and had lower pressure rise and temperature rise than at 80 psi. Some are using 72 psi and I will try that the next time to see if the numbers improve.
49 CFR 571.110
Tire selection and rims and motor home/recreation vehicle trailer load carrying capacity information for motor vehicles with a GVWR of 4,536 kilograms (10,000 pounds) or less.
S4.2.2.1
Except as provided in S4.2.2.2, the sum of the maximum load ratings of the tires fitted to an axle shall not be less than the GAWR of the axle system as specified on the vehicle's certification label required by 49 CFR part 567. If the certification label shows more than one GAWR for the axle system, the sum shall be not less than the GAWR corresponding to the size designation of the tires fitted to the axle.
S4.2.2.2
When passenger car tires are installed on an MPV, truck, bus, or trailer, each tire's load rating is reduced by dividing it by 1.10 before determining, under S4.2.2.1, the sum of the maximum load ratings of the tires fitted to an axle.
S4.2.2.3
(a) For vehicles, except trailers with no designated seating positions, equipped with passenger car tires, the vehicle normal load on the tire shall be no greater than 94 percent of the derated load rating at the vehicle manufacturer's recommended cold inflation pressure for that tire.
(b) For vehicles, except trailers with no designated seating positions, equipped with LT tires, the vehicle normal load on the tire shall be no greater than 94 percent of the load rating at the vehicle manufacturer's recommended cold inflation pressure for that tire.
Old 10-23-2014, 06:04 AM   #92
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by r carl View Post
Are you defending st tires?
No, I am pointing out that there has more to these changes than just a change from ST to LT - or from Goodyear to Michelin. There are multiple changes being made and i think everyone selects one as the one that made the difference - and they forget about the others.
CapriRacer is offline   Reply With Quote
Old 10-23-2014, 08:15 AM   #93
dkottum's Avatar
Switz, thanks for the excellent user's report on both 15" and 16" Michelin upgrades and your reasoning for the tire pressures you have chosen.
Doug and Cheryl
Old 10-23-2014, 08:46 AM   #94
TinTin's Avatar
Canmore , Alberta
Originally Posted by switz View Post
49 CFR 571.110
S4.2.2.1
S4.2.2.2
S4.2.2.3
This is the key information, of value to anyone switching ST to LT!! Thanks Switz. Do you have the original link to these regs?
Bob and Nancy
Old 10-23-2014, 02:01 PM   #95
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Another possible tire for those looking for a 15" tire is the General Grabber HTS P235/75/r15 XL with a weight rating of #2271 (derated #2043) - a few more than the Michelin and less money.
I had these put on my brothers box utility trailer which was just taken to Saskatchewan on a trip. He paid ~$120 each plus there was a $70 rebate for 4 tires.
With the weight ratings this 15" tire and the info that Switz published i could probably squeek by with my 8400 gvw trailer. My weight tickets for the airstream axle load is #7400.
Grabber HTS
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-23-2014, 02:20 PM   #96
switz's Avatar
2014 31' Classic
Images: 8
As the load on the axles get closer to the tire maximum rating, there is less lee way for a heavy corner. Both our 25FB and Classic were/are 200 pounds heavier on the street side rear wheel. Thus the need for some wiggle room.
The 25 models with 7,300 pound GVW and the 27/28 models with 7,600 pound GVW will work with the 15" Michelins as wood most tri-axle models.
Old 10-24-2014, 05:34 AM   #97
switz's Avatar
2014 31' Classic
Images: 8
Here is a link:
http://www.gpo.gov/fdsys/pkg/CFR-201...sec571-110.pdf
Old 10-24-2014, 09:04 AM   #98
TinTin's Avatar
Canmore , Alberta
Many thanks, switz!
Bob and Nancy
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Tire pressure with T03s and Michelin LTX dsaxon22 Tires 27 02-04-2014 06:11 AM
Do you tow in "use" or "store"? xo1rider 2011 - 2015 International 17 11-06-2011 09:20 AM
Newbie electrical questions -- "Use" and "Store"? jjboone101 Batteries, Univolts, Converters & Inverters 8 08-27-2009 09:44 PM
