Old 10-09-2014, 03:53 PM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Originally Posted by slowmover View Post
TT tires need always be at max sidewall pressure to resist lateral sway. Other considerations are FAR down the list.
This is not true.
Old 10-09-2014, 03:54 PM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Travel trailer tires at max sidewall pressure. Is there a reference to support that?
Doug and Cheryl
Old 10-09-2014, 03:56 PM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Pressure rise and temperature rise were less at 75psi than 80 psi using a certified digital pressure gage when checking ststic pressures and the Dill TPMS when under way. We were around 9,200 trailer losded weight before hitching to ProPrideweight distribution system
Old 10-09-2014, 03:59 PM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Sure. Try the TT manufacturers. Ask either of the tire engineers who post here. The problem in upsizing to use 16's is that load range is hard to match
Old 10-09-2014, 04:20 PM   #19
SteveH's Avatar
Common Sense , Texas
If your travel trailer sets in one spot all the time and never moves, it really doesn't matter what the tire pressures are.
Regards,
Steve
Old 10-09-2014, 04:35 PM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
What pressure do you use 16" Michelin?
When they sit pressure can be upped 10% past max
Old 10-09-2014, 04:37 PM   #21
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Michelins LT 225-16's, 65-67 cold, triple axle, 1500 miles trip, max speed 65 , max pressure increase 4-5, max tire temp 100 with temps around 90
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 10-09-2014, 04:52 PM   #22
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
SteveH, that's not a Travel Trailer, that's a Mobile Home!
Bob Martel
WBCCI# 5766
Old 10-09-2014, 04:52 PM   #23
dkottum's Avatar
We're hitting the road in the morning so I took the consensus here and used the load information and recommendation of Andrew T. and set them at 65 psi as a good place to start. It's very cool here and early November we'll be in the desert, so will check them along the way.
Slowmover, I did some reading on your max weight recommendation and only found a reference that matches your thoughts when using ST tires. And then the concern was more about overloading and uneven wear ST tires on trailers in general rather than stability. Apparently LT tires are not used enough in our application for a specific recommendation. Maybe one of the expert engineers will weigh in, they often do.
Meantime we have to sort out the wide range of experience and wisdom and settle on something reasonable. For us it looks like 65 psi for our 16" Michelins. If there is sway our ProPride hitch will make it hard to detect, for better or worse.
Doug and Cheryl
Old 10-09-2014, 04:55 PM   #24
Chelsea , Michigan
Images: 12
Doug, I am confident that you will be fine at 65 psi .
Safe travels and have a good winter! We "launch south" on 11/11.
Bob Martel
WBCCI# 5766
Old 10-09-2014, 05:02 PM   #25
dkottum's Avatar
Thanks Bob. We may cross paths, we're headed SE first to tour, visit friends and family. No hurry, some of the most interesting experiences are not planned. We're WBCCI# 1211.
Have a great trip as well.
Doug and Cheryl
Old 10-09-2014, 05:05 PM   #26
SteveH's Avatar
Doug,
You will more than likely be fine with 65 PSI in those tires on your trailer. The way to know if you are underinflated is if when towing at highway speeds in hot weather the air pressure increase is 10% or more of static pressure, you need more.
Regards,
Steve
Old 10-09-2014, 08:08 PM   #27
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Lateral stability is the top reason . . . not causing internal tire damage in turns is the lasting problem. This has been discussed on this forum and elsewhere. The Load & Pressure Tables do not apply to trailer tires.
Old 10-09-2014, 08:12 PM   #28
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
I picked up my new Michelins this week. I lost two ST tires within 300 miles recently so the reason for the change. The dealer knows tires but probably not load etc. They came to me at 70 psi so that is what I will run unless someone changes my mind.
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
GAT is offline   Reply With Quote
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Tire pressure with T03s and Michelin LTX dsaxon22 Tires 27 02-04-2014 06:11 AM
Do you tow in "use" or "store"? xo1rider 2011 - 2015 International 17 11-06-2011 09:20 AM
Newbie electrical questions -- "Use" and "Store"? jjboone101 Batteries, Univolts, Converters & Inverters 8 08-27-2009 09:44 PM
