Old 10-11-2006, 06:59 AM   #15
1975 27' Overlander
High River , Alberta
7.00 x 15 hard to find but still available
I have seen 7.00 x 15 Toyos on a '76 Tradewind. I think they're actually LTs, like the original Airstream tires were.
Yokohama or Bridgestone may also supply 7.00 x 15s, if you are interested in having the correct size for the trailer. You would have to ask a knowledgeable dealer to find them.
AlbertF is offline   Reply With Quote
Old 10-11-2006, 07:38 AM   #16
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I don;t think the speed rating is determined by the "ST" label
  • Speed rating: VR (V-rated radial)
  • In this case, V identifies a speed rating above 149 mph.
  • Table 1 lists speed ratings.
  • The R means the tire is a radial. Virtually every new tire is a radial, unless you have a special tire for a classic car or a racing car.
Table 1: Speed Rating Designations
Speed Designation
Maximum Speed Rating
N
87 mph
P
93 mph
Q
99 mph
R
106 mph
S
112 mph
T
118 mph
Why Use An "ST" Tire
  • "ST" tires feature materials and construction to meet the higher load requirements and demands of trailering.
  • The polyester cords are bigger than they would be for a comparable "P" or "LT" tire.
  • The steel cords have a larger diameter and greater tensile strength to meet the additional load requirements.
  • "ST" tire rubber compounds contain more chemicals to resist weather and ozone cracking.
'77 Sovereign Intl 31' CB
Old 10-11-2006, 08:44 AM   #17
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
A Bit of the Difference is
Originally Posted by golddigger
I have always wondered: what is a trailer tire? What makes it different from, say, a truck tire? Why would I not want to put an LT on a trailer? Could I swap the Good Year Marathon load range D 225/75R15 for 225/75R15 LTs with load range D?
Trailer tires and wheels are subjected to side loading. This explained to me was when we turn tightly towing the trailer, more force is exerted on the tire and wheel in a direction that it is not necessarily rolling in. ie (scrubbing)Sideways forces are not applied to the tow vehicle in the same manner. When our tow vehicles are turning, there is no wheel or tire "scrubbing" therefore our tires are "rolling." ST or special tires are designed for these sideloads. LT light truck tires are not. Also, If you look at the weight ratings for the LT tires, they usually carry a lot less weight than the trailer special tires.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-11-2006, 09:27 AM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
[LIST]
Bob,
I believe the speed ratings that you listed (and there are more) apply only to "P" or passenger tires. I have not seen any of those speed ratings on an LT or ST tire.
>>>>>>>>>>>>>>>>Action
Action is online now   Reply With Quote
Old 10-11-2006, 11:18 AM   #19
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Y'all can do what you want.
Having been in the tire and automotive industry for more decades than I care to think about, believe me when I say an ST tire is speed rated for 65 miles per hour, NOT 112.
Old 10-11-2006, 12:02 PM   #20
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Isn't the ST tires on all new A/S's, hard to believe they are limited to 65mph?
Not that I doubt what your saying, but where is this stated by tire manufactures?
Old 10-11-2006, 12:24 PM   #21
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Another good read
In order to select the proper load range, you must first weigh your trailer fully loaded. This means full of water, LPG and gear. Go to a truck stop or public scale and weigh the entire rig. While you are there, weigh each axle separately. This will let you know if you have exceeded the tow rating of your tow vehicle or are overloading one of the trailer axles.
There are other considerations in picking ST tires. For the trailer tires to manage the weight, all must be identical. Do not mix bias and radials tires. What's more, the load range and size of each tire should be the same. And each should have the same amount of tread wear. This becomes critical when replacing a tire.
When replacing a single tire, always run the same size outside diameter tires on the same axle. A smaller- diameter tire will carry more weight, and may become overloaded.
After a blowout on a tandem-axle trailer, you should replace both tires on that side. The remaining tire was likely subjected to excessive loading and, as a consequence, may fail in the near future.
MAINTENANCE TIPS
When a trailer is in long-term storage, there are steps you can take to add life to the tires.
  • Put the trailer on blocks to take weight off the tires.
  • Lower the air pressure.
  • Keep the tires covered to protect them from the sun's ultraviolet light.
When taking the trailer out of storage, make sure there are no cracks in the grooves and no wire showing. Cracks in the sidewall could indicate interior damage or separations in the tire.
MAXIMUM PSI?
As indicated earlier, maximum load range is attained only when the tire is at its maximum air pressure. Yet, should you maintain maximum pressure even if you are towing below the load range of the tires?
Tire manufacturers differ on this point. "You should maintain the maximum pressure at all times," says Carlisle's Garbarino. "There is no advantage to taking air out of the tire. With maximum pressure, the tire will perform and wear better, and you will get better mileage. Reduce the psi, and you compromise the functionality of the tire."
Titan Tire's Evans feels differently. "If you want a little softer ride, drop the psi a bit," he says. However, he cautions that: "They have to know the actual load."
"Trailer owners should set the pressure according to the load," says Goodyear's Fry, who provided the tire pressure vs. load chart that accompanies this story. "Yet, this is not easy to do without weighing the trailer."
"Once the weight is accurately determined, the pressure should be set when the tire is cold, not when it is hot."
All the manufacturers agree on one point: If you do not know the exact weight of your trailer, keep the ST tires at the maximum cold psi.
Based on updated thinking, there are ultimately three keys to avoiding tire trouble while towing: (1) Make sure your rig is equipped with the proper tires: (2) maintain the tires meticulously: and (3) replace trailer tires every three to five years, whether they look like they're worn out or not.
As my grandfather used to say, take care of your equipment, and it will take care of you.
Old 10-11-2006, 12:40 PM   #22
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Here's what Tire Rack has to say about LT tires:
"LT = If a tire size begins with "LT," it signifies the tire is a "Light Truck-metric" size that was designed to be used on vehicles that are capable of carrying heavy cargo or towing large trailers. This includes medium and heavy-duty (typically 3/4- and 1-ton load capacity) pickup trucks, sport utility vehicles and full-size vans. Tires branded with the "LT" designation are the "little brothers" of 18-wheel tractor-trailer tires and are designed to provide substantial reserve capacity to accept the additional stresses of carrying heavy cargo."
In the trucking industry they distinguish between steering axle and non-steering axle use. The side loads on a tire used on a steering axle are far more severe. The oft repeated arguement that our RV trailers have some huge side load and are subect to "scrubbing" that doesn't exist on the TV doesn't hold up. The rear axle on a car has the same "scrubbing" action as a trailer. Far worse if it's on a dual axle configuration or attached to a limited slip differential. Plus, most people tend to corner much faster when they're not towing and a 1 ton pick-up with a giant camper is as heavy and has a higher CG than just about any Airstream.
The "superior construction techniques" in ST tires is likewise just marketing euphimisms for cheap construction. They increase the diameter of the cords to get a higher max inflation pressure and increased load capacity. Look at an ST tire and an LT tire of comparable load and the LT tire will be heavier, more expensive and meet far stricter standards. LT tires are derated because they're going to be used for carrying "live cargo". That's one of the reasons the ST tires have a high rated load capacity for the price.
Again from the Tire Rack:
Speed Rating
"Today, the only tires that continue to include the speed rating "in" the tire size (P225/50ZR16) are Z-speed rated tires. In this case, following the two digits used to identify the aspect ratio are the letters ZR to identify the tire's speed rating (Z) and its internal construction (R). Since 1991, all other speed ratings are identified in the tire's Service Description
A Service Description identifies the tire's Load Index and Speed Rating. Service Descriptions are required on all speed rated (except for Z-speed rated) tires manufactured since 1991.
The significance of the speed rating is that it's a measure of how well the tire disipates heat. The hotter the outside temperature or the faster you go the lower the load carrying capacity of your tires. In addition LT tire usually carry UTQG markings. "
All "ST" tires have a maximum speed rating of 65 mph. It's a well disguised fact because if dealers and manufacturers made the facts readilly available they'd have a hard time selling tires. Remember that on a hot day your max speed goes down and tire degredation from heat further diminishes the capability of the tire.
LT tires are available in 7.00X15R but they're hard to find. I'd love to get a Toyo in that size. I was just in a local Les Schwab dealer inquiring about this since they're the largest Toyo dealer in the west and I've always been happy with their service. It appears that the Toyos in this size are no longer imported to the US although they're still very common in Asia. Likewise Michelin seems to have stopped importing this size. Yokahma is the only choice I've found other than private lable brands.
bhayden is offline   Reply With Quote
Old 10-11-2006, 12:51 PM   #23
Well Preserved
1993 21' Sovereign
http://www.discounttire.com/dtcs/infoTrailerTireFacts.dos;jsessionid=FjdZTL21TVhG3d YkGLRd84gQMBwyXLNbGGm2WwQt0yS8TbNm0DF5!1088327042! NONE
Old 10-11-2006, 02:18 PM   #24
bhayden's Avatar
1978 24' Argosy 24
If only it were that GOOD!
  • Time and the elements weaken a trailer tire.
  • In about 3 years roughly one third of the tire's strength is gone.[read, your speed/load rating is less]
  • Three to five years is the projected life of a normal trailer tire.
  • It is suggested that trailer tires be replaced after 3 to 4 years of service regardless of tread depth or tire appearance.
Mileage
  • Trailer tires are not designed to wear out.
  • The life of a trailer tire is limited by time and duty cycles.
  • The mileage expectation of a trailer tire would be 5,000 to 12,000 miles.
5-12k miles, that's great for driveway sailors but doesn't cut it if you plan any long trips in the heat of summer. I can't find the specifics of the test for ST rating but it's been brought up before that the temperature the 65mph rating is derived at is significantly below the actual conditions many people encounter. UV and concrete slabs aren't the only reason trailer tires "rot". Heat literally destroys them from the inside out. Think about it, how many car tires crack and bulge after 3 years and they don't even have the "extra chemicals to resist weather and ozone cracking." Sure storage is hard on tires but collector cars or abandon vehicles out in a field don't have this problems to anywhere near the extent seen with trailers.
Old 10-12-2006, 01:21 PM   #25
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
All this tire talk and I blew the right rear out on my dually yesterday. Thank goodness the inside was there to keep the rig steady. 1 1/2 hours and road service had me going with new tires on the RR. I now have a spare that is only 4 years old.
WBCCI 17109
Old 10-12-2006, 01:36 PM   #26
1984 31' Excella
Norfolk , Virginia
Images: 11
What is the Right Size Tire?
1. Goodyear Marathons are Speed Rated to 65 mph. Go to the Goodyear web site:
http://www.goodyear.com/rv/pdf/marat...nfo_032806.pdf
to read a statment by Goodyear concerning this fact.
Here are the load inflation tables on the Goodyear site:
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
2. According to the poll on this web site, "Your Towing Speed"
http://www.airforums.com/forums/f232/poll-43-your-towing-speed.html
51.65% of the respondents tow their trailer at 65 mph or faster. 65 mph leaves you with 0.00% safety margin on the tires design loading and speed.
I wonder if that could be the reason for so many ST failures? To this add:
"Based on industry standards, if tires with the ST designation are used at speeds between 66 and 75 mph, it is necessary to increase the cold inflation pressure by 10 psi above the recommended pressure for the load".
"Cold inflation pressure must not exceed 10 psi beyond the inflation specified for the maximum load of the tire."
Great, now we are supposed to overinflate the tire iif we are going to overspeed the tire. Why, so we will stand a better chance of hearing it when it goes (smart remark) or to stiffen the sidewalls to reduce the increased flexing of the sidewalls thus reducing the internal heat build up which will ultimately result in the failure of the tire?
3. There are 16 inch tires avaliable(G.B.Goodrich Commercial T/A LT225/75R16 LRD, 110/107Q) (Q=99mph) that are the same Outside Diameter (OD) as the original 7.00/15 Michelin XCA that came on a lot of Airstreams and the same width as the ST225/75R15 Marathon that Airstream recommends. With the proper wheel, the 16's work nicely.
Beginner
Beginner is offline   Reply With Quote
Old 10-12-2006, 03:01 PM   #27
Frank S
peoria , Illinois
Hi AlbertF--7.00x15LT D Goodyear "Work Horse Rib" bias construction are easy to find if you go to WalMart. They have them for $107.20. Load rating is 2045# @ 65psi--Frank S
Frank S is offline   Reply With Quote
Old 10-12-2006, 11:58 PM   #28
1960 24' Tradewind
santa barbara , California
Many thoughts on tires as always ,65mph on marathons period .Thats it.
Well documented fact . The heat is what kills and too much load on the tires
cause many failures .
Scott
scottanlily is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
Tire size help please MatthewX Tires 3 04-20-2004 07:56 AM
tow vehicles paul k Tow Vehicles 96 01-19-2003 09:59 PM
tire size? goodgrey Tires 8 01-06-2003 08:27 PM
325 MH tire size? TRAPEZE Tires 2 12-12-2002 08:31 AM
