Old 08-30-2012, 08:13 PM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
What is the inflation pressure limit for 15" steel wheels?
Trailer came with load range C tires and steel wheels. Does anybody know what the pressure limit is for these wheels? I have it in my mind that I have seen that the wheel is limited to 50 PSI ?
Old 08-30-2012, 08:34 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The limit for load range C tires is 50 psi. The wheels may be more, and may be stamped on them.
Old 08-30-2012, 08:50 PM   #3
1988 25' Excella
1987 32' Excella
Thanks. It is the wheels I am asking about. Guess I will have to take one off and look at it close. Can I put D's on the steel wheels and run them at 65 psi?
Old 08-30-2012, 09:20 PM   #4
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Rivet pressure pressure
All tires will have molded in the sidewall the tire pressure max for the tire, your airstream, as all vehicles, have the spec tires required and pressure to set the tires at for the rig or play Russian Roulette with your life.
arcamedies is offline   Reply With Quote
Old 08-30-2012, 09:26 PM   #5
dznf0g's Avatar
Oswego , Illinois
It just depends on the wheel originally spec'ed. You will have to inspect one of the wheels closely. The max spec may be on the inside of the rim.
-Rich-
Old 08-31-2012, 07:46 AM   #6
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Dexter wheels list the greatest inflation tire pressure for a 15" steel wheel at 80 PSI
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
