Old 10-25-2007, 04:57 PM   #1
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
What do you know about this brand tire?
I have been reading the tire failure post and decided to do a search on other travel trailer tires. I came up with the following name brand. Do any of you guys have any "info" on their quality?
The LOADSTAR Karrier ST radial
Utility & Boat Trailer Tires / Aluminum, Galvanized & Painted Trailer Wheels
S/Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 10-25-2007, 05:39 PM   #2
1984 31' Excella
Norfolk , Virginia
Images: 11
What do you know about this brand of tire?
That tire is made by Kenda. Here is there web site:
Kendausa
Here is the answer I got when I was searching for a tire better than the Marathon. Replys like this one drove me to go to 16 inch wheels and LT tires.
You may not know this sender. Mark as safe | Mark as unsafe
Sent: Thu 10/20/05 11:05 AM
To:
Cc: Cindy McGrail (CMcGrail@kendausa.com)
Hi ,
The trailer tires all designed for speed rating at 65 mph. Lots of people towing at much higher speed is not what tire manufacturer recommended.
The consideration of upgrading to 16" tire seems related to loading capacity issue instead of speed rating issue. As far as I know, there's no 16" tire has same loading capacity with same OD as 15" tire. Even if it has that most likely will be a LT tire not the trailer tire. You will having the risk of using LT tire or pay more for people make the reinforced LT tire to be fit for trailer application.
We will have a 10P ST225/75R15 tire at 2830 lbs capacity available soon if that's what you need.
Hope this help!
Hank Chang
Beginner
Beginner is offline   Reply With Quote
Old 10-25-2007, 06:01 PM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Check out the "about Kenda" link on the site.
www.nesa.org
Air No. 6427
Old 10-25-2007, 08:04 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If you want a 10 ply rated ST 225 75R 15 tire, Maxxis has an E rated model. I'll get mine Sunday and will get them mounted next week.
Jack
Jack Canavera
STL Mo.
AIR #56
Brand New lernerfilm@e Member Introductions 5 03-05-2007 09:45 PM
Brand New Guy windytd Member Introductions 6 01-27-2007 09:19 AM
OK now what brand? McLogger Axles 6 10-21-2006 06:02 PM
Best brand Furnace? 65 overlander Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-14-2006 07:55 PM
AC Brand Talk Over59 Furnaces, Heaters, Fireplaces & Air Conditioning 5 03-06-2005 08:47 AM
