Old 08-29-2016, 03:28 PM   #1
1961 22' Safari
Collegeville , Pennsylvania
What are good alarm settings for a TPMS?
I'm planning on installing a TPMS and it seems most will give you a warning if the pressure gets too low or the temp gets too high.
If the temp goes up, pressure has to go up too, right? If the max cold pressure on the sidewall is 65 PSI and you set it there, is there a pressure above 65 that should concern you or is it just temperature?
Basically, I'm wondering if there is there a rule of thumb for setting the "warning point"?
How hot is too hot and how low is too low?
TheHandyDan is offline   Reply With Quote
Old 08-29-2016, 03:33 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My Dill system had a default alarm percentage for pressure and a fixed alarm temperature. I just inflated the tires to the proper pressure and then initialized the system. I think I could adjust the pressure alarm percentage, but I just went with the default.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 09:37 PM
TPMS settings ghaynes755 Tires 0 01-15-2014 05:45 PM
Equalizer Installation Settings temcotom Hitches, Couplers & Balls 5 06-13-2004 11:56 AM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 07:29 AM
