Old 03-06-2013, 07:54 AM   #1
AlamoRunner
2012 23' Flying Cloud
San Antonio , Texas
What about options on tires for 14 inch rims?
I am going to throw this up for discussion after looking through the forum and not finding anything dealing with the problems of the 14inch wheels and tires used on 23s and maybe some others.
I have a 2012 FC 23C, tandem axle, 14 inch wheel and GYMs. Made it through my first year without incident, but just had a road hazard induced low speed failure on one of the GYMs. Now that I am looking to replace, am considering a full GYM replacement due to the widespread history of problems noted on the forum.
It looks like I am stuck with ST tires if I keep the 14s. That keeps me with the inherent compromise of ST tires which just doesn't work in our area with the 75mph freeway limits and high summer temps. Does anyone have any info about a 14 to 15 upgrade in order to go with the Michelin LTX/2 XL rated tires? I really doubt that going all the way to 16s is workable from a wheelhouse space and axle spacing limit.
I see lots of people with larger trailers going from 15s to 16s, but haven't seen anyone solve the 14 problem yet.
Anyone out there already deal with this issue?
Thanks.
AlamoRunner is offline   Reply With Quote
Old 03-06-2013, 10:49 AM   #2
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Assuming your GVWR is 6k, these tires will exceed that by almost 1500 lbs at 14", and at only $86 per tire.
Continental*Vanco 2
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 03-06-2013, 10:55 AM   #3
1988 32' Excella
Robbinsville , New Jersey
Check these threads.
http://www.airforums.com/forums/f485...els-96910.html
http://www.airforums.com/forums/f438...-lt-96716.html
http://www.airforums.com/forums/f468...ade-79713.html
http://www.airforums.com/forums/f465...ade-40248.html
Old 03-15-2013, 05:21 PM   #4
RMB
RMB's Avatar
2010 23' International
Saturna , British Columbia
I just had the same issues for my 23' International. I changed the rims to 15" and went with Michelin ST tires. See my posts and photos.
I just returned for a 1.5 month trip to Mexico and its bad roads; from 65 mph on I-5 to crawling on broken, pot hole riddled pavement, many "rustic" campgrounds with dirst and crushed gawd-knows-what underfoot and a few very hard bumps on unseen topes and vados.... No problems at all from my tires.
"I carry what I can, and leave the rest behind" Epicurus
"All that is mine, I carry with me." Cicero
RMB is offline   Reply With Quote
Old 03-15-2013, 08:10 PM   #5
1999 25' Safari
Vienna , Virginia
http://www.tirerack.com/tires/TireSe...=0&diameter=14
I am running kumho 857 14s on my 1999 25ft I have about 8k on them so far good. They have a higher speed rating than gym do
Jackstincan is offline   Reply With Quote
Old 03-26-2013, 08:18 PM   #6
2005 16' International CCD
2015 Interstate Coach
Bandon , Oregon
Our QuikSilver Edition 16-footer blew a GYM tire on the way back from Arizona. Fortunately, no damage. Replacing with 15-inch wheel-tire seems to be a virtually impossible since there isn't the room at the rear of the wheel well. Any suggestions for a suitable and safe replacement for the 14-inched? Any help would be appreciated.
Rapa Nui is offline   Reply With Quote
Old 03-26-2013, 08:30 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I messed with the 14s on our '65 Caravel for several years. Finally changed to 15s. Many more tire options.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 03-27-2013, 09:29 AM   #8
Bandon , Oregon
Thanks Jim... I would really like to go to 15s but I'm afraid the tires won't fit. There's only about an inch of room between the tred and the back of wheel well. I've heard that ST215/75R-14/6 Tow Max trailer highway tires are a possible and good choice for the GYMs. Any thoughts?
Old 03-27-2013, 10:16 AM   #9
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Yup, I went 14" > 15"
on my '99 Safari 23'. There are several issues to consider:
1. Wheel well clearance. Do "measure twice and cut once." You can get tire dimensions from many websites, such as Tire Rack. On mine, I wound up with less than an inch of clearance with the new tires, and so I suspect that IF I have a blowout, there'll be more sheet metal damage.
2. Spare tire carrier clearance. Again, do the smart thing and check first. My new 15" spare will JUST, with a lot of oomph, allow me to swing the spare tire carrier up and lock in place. Of course, you can modify the carrier, but be sure you know what you're getting into first.
3. Brakes. My coach has 10" brakes (if I recall correctly), and a 15" diameter tire/wheel has more leverage against the brakes than a 14" one does. Not a big deal perhaps, but worth considering.
4. Construction. ST tires are built different from light truck tires, and while the mfrs. don't let me in on how they build their tires, I'd strongly suspect that LT tires have lighter, thinner sidewalls (this gives better heat dissipation and thus higher speed ratings) - but the downside is that they are then more susceptible to "curbing" damage. Don't hit curbs, etc. and this is probably a non-issue ... but accidents happen, you know?
All that said, while I was very happy with my GYMs and had no issues whatsoever over tens of thousands of miles of towing, I'm also pleased with my Michelin LTXs also. I've got probably 15k miles on them so far, and all is well. They also, for some reason seem to hold air pressure better, but that could just as well be a rim issue or an issue of having a tiny bit of dirt at the rim/tire seal point, etc. Finally, though I run the Michelins at about the same pressure as the GYMs, they seem to run five to ten degrees cooler. Could be sidewalls flexing easier, aluminum wheels dissipating heat better than the stock steel wheels, etc.
Good luck!
AirsDream is offline   Reply With Quote
Tow vehicle tires: Different tires for summer and winter? Jammer Tires 9 02-15-2012 03:03 PM
Larger tires on 15" rims, 235-75R15LT etc Jammer Tires 2 02-06-2012 01:16 PM
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
1961 Bambi wheel rims jennings0566 Wheels, Hubs & Bearings 2 08-24-2011 12:10 PM
1965 overlander tires and rims? buddyboy54 Tires 3 08-03-2011 08:04 PM
