10-19-2015, 07:57 PM
2012 27' Flying Cloud
W
, New England
Weird Marathon Picture - what happened?
A member of the New England Unit shared this picture on our Facebook and gave me permission to share it here in hopes maybe our tire engineer folks could chime in on this. What happened here?
10-19-2015, 08:15 PM
2007 22' International CCD
Corona
Goiter?😄😄
10-19-2015, 08:18 PM
W
, New England
Originally Posted by rmkrum
Goiter?😄😄
Now, that's your *professional* opinion? 😜😂
Honestly - that is the strangest thing I've ever seen on a tire! How is that even possible?!?! 😳
10-19-2015, 08:25 PM
Refugee from Napa, CA
2015 25' Flying Cloud
Formerly Napa
, On the road
SPARE TIRE ate a BOWLING BALL.
Instagram. Alluminator
10-19-2015, 08:28 PM
Corona
Seriously it looks like air leaked between layers of the tire, as a guess a manufacturing defect or weird damage. Another reminder to use better tires😞😞
10-19-2015, 08:30 PM
Corona
....or just a lack of iodized salt in its diet.
At least it is an obvious problem that would lead to not using that tire.
That's my story, and I'm sticking to it.
10-19-2015, 08:55 PM
1998 31' Excella 1000
South Berwick
, Maine
That's my tire, second one that failed this way with less than 5000 miles, LR D. Another one just shredded and destroyed the skin aft of the wheel.
WBCCI 24291
New England Unit
Metropolitan NY Unit
10-19-2015, 09:20 PM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Looks like the average Marathon to me. Move along. Nothing to see here.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
10-19-2015, 09:34 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
I've seen a high pressure water hose do the same thing. Water just found a week spot in the fiberglass belts in the hose, didn't quite puncture the outer layer of rubber. A pinprick and it'll blow like crazy - stand back, wear eye protection!
10-19-2015, 09:35 PM
1999 34' Excella
Hillsboro
Same location on the AS?
Besides bad tire I suggest checking alignment.... Toe and Camber, distance between axle spindles... Check spindle, bearings, rim/wheel for damage..
How slow do you tow?
Is AS running "level" ???
What are weights of AS when running?
Peace and Blessings..
Channing
WBCCI# 30676
10-19-2015, 09:40 PM
1969 25' Tradewind
Shasta Lake
What's the date code ?
How long have you had the tire ? Not miles, But time.
This is a separation at the tread edge that allowed air to bulge the sidewall between layers.
Usually the steel belt punctures the rubber and lets the air out.
10-19-2015, 09:50 PM
1999 34' Excella
Hillsboro
Channing
WBCCI# 30676
10-19-2015, 09:57 PM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
It's a TUMOR, in your best Arnold voice.
Sorry couldn't help it.
Hittenstiehl
10-19-2015, 09:58 PM
1993 34' Excella
Estancia
, New Mexico
Sidewall separation from running flat, low pressure or impact with a curb?
Could also be an implanted alien baby.
South Berwick
, Maine
Tow a 31' and travel light, all tanks empty. Tire was about 6 years old, low mileage and never in the sun. On the way to campsite last weekend, all tires exhibited normal temps and pressures monitored by TPMS. Highway travel between 60-65 mph. Noticed bubble (much smaller) while emptying tanks before departure (lucky to change prior to being on the road). When we got home, went to check pressure of tire in back of truck and there you have it. The tires on my Excursion are 12 years old with 75K, sits outside in the summer, tire dealer says keep running then until visible sign of deterioration or below min tread. Bearings maintained. Can't say much about alignment, but tow absolutely level.
WBCCI 24291
New England Unit
10-19-2015, 10:04 PM
1993 34' Excella
Estancia
, New Mexico
A 6 year old tire is at the end (or past depending on who you talk to) of it's useful life regardless of the mileage.
10-19-2015, 10:21 PM
1993 34' Excella
Estancia
, New Mexico
From everything I have heard 12 years is a geriatric tire. Tires deteriorate from the inside out. Personally I would run from this dealer.
South Berwick
, Maine
I figured there might be consensus on age, but I'm having trouble digesting that. I can see a sun damaged tire with visible sidewall cracks and such, but a tread/sidewall bubble while still holding 65#, blame failure on age?
WBCCI 24291
New England Unit
10-19-2015, 10:29 PM
South Berwick
, Maine
WBCCI 24291
New England Unit
10-19-2015, 10:36 PM
South Berwick
, Maine
Just wondering, my 2003 Excursion, never had the spare ever removed from stowed location, should I replace that too?
WBCCI 24291
New England Unit
