12-11-2015, 11:32 PM
#121
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Be that as it may, the previous Michelin tire is rated at 108T and the new Defender is rated at 109T. Don't know what that means for "durability", but it does mean the new Michelin Defender tire is rated to carry slightly more weight. Right?
12-12-2015, 05:25 AM
#122
CapriRacer
I'm in the
, US
Sort of.
What's being encountered here is the difference between the American way of calculating load carrying capacity (ala The Tire and Rim Association - TRA) versus the European way (ala European Tyre and Rim Technical Organization - ETRTO). Not only is there a difference because of the measuring systems (English vs Metric), but there is a slight difference in the formula. For practical purposes, it isn't a difference at all. In other words, that alone does NOT have an effect on durability as the tire design would be the same in both cases.
12-12-2015, 05:33 AM
#123
Mantua
, Ohio
But the weight safety margin would be greater.
12-12-2015, 09:34 PM
#124
2013 25' FB Flying Cloud
Longmont
US vs. European tire rating
Originally Posted by CapriRacer
Sort of.
Interesting! So you are saying that for a given tire design, if the manufacturer labels it with a "P" they have to use the TRA formula and units, and if they label it without a "P" (or LT or ST) they have to use the ETRTO formula and units. AND they can come up with a different load rating, higher for an ETRTO tire?
12-12-2015, 10:45 PM
#125
2016 30' Classic
The Beautiful Mountains Of Southwest
, Virginia
Another China Bomb!
Luckily, looks like that one is still "unexploded!" I'll tell you what happened....all ST tires are made in Asia now days. They are all JUNK! The best money that you will ever spend, if you are planning on towing, will be to replace all your ST tires with 16" LT tires, preferably USA made. Then if you run the max pressure listed on the sidewall, you will never have to worry about your trailer tires again. It's just that simple! Everyone tries to explain this with some "educated guess." Really, it's just not that hard. Look around at all the other "great" products we get from China..... lol.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
12-13-2015, 05:07 AM
#126
CapriRacer
I'm in the
, US
Not exactly. Remember the construction of the tire is exactly the same - so when the tire is applied to a vehicle, it doesn't matter what which standard was applied - the tire behaves the same.
Put a different way, when a tire is properly designed, the tire engineer can apply either standard and label the tire accordingly. It will pass the tests regardless.
Not exactly. LT and ST standards are TRA. ETRTO uses a "C" (for Commercial) after the numbers in place of LT and doesn't have an equivalent of an "ST" designation. Plus there is another standardizing organization JATMA (Japanese Automobile Tire Manufacturers Association) that also doesn't use the letters for passenger car type tires (and they have a third different formula).
12-13-2015, 05:24 AM
#127
CapriRacer
I'm in the
, US
Woopsy! Posted in the wrong thread.
12-13-2015, 11:25 AM
#128
Tavares
Originally Posted by Andrew T
"Andy - For the avoidance of doubt as they say, you are talking about this tire?
http://www.tirerack.com/tires/tires....TR5LTXMS2OWLXL"
Sorry I did not get back to this thread sooner. To answer your question, this is the tire we use on most Airstreams.
The Defender looks to be a slightly different tire, it weighs 2 pounds more on its spec. This can mean it is even more durable as there is more structure in it. Also though there is more unsprung weight though not very much.
Once they are available I will put a set on a high mileage unit to test but in the mean time it might be better to stay with the one that is proven.
Interesting we had a customer on the Newfoundland Caravan last summer. His Michelins were 4 or 5 years old on his 30' Classic with plenty of miles on them. He mentioned other tires were dropping like flies but not a problem with his.
Andrew T
Thanks very much Andy.
I'm sorely tempted to dial up Tirerack and order up a set of these for my 2016 27 FC FB.
As a retired, risk averse Systems Engineer, I see the benefit of doing this sooner rather than later, at least before we get on the road for the big trip next spring.
My plan would be to get the four Michelins, and have them mounted and balanced with short metal stems on my 15" wheels here in Tampa. I'd replace the dual chrome lugs with the McGuard one piece nuts.
I just have to go look one more time at the weight specs of my trailer, in order to make sure I don't need to go to the 16" wheels. (I don't think so?).
All I need then is to ask Santa for a special xmas delivery.
If anyone sees a flaw in that plan, please let me know.
Much obliged for all the comments in the thread, as a newbie, I find it very interesting.
Rich
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
12-13-2015, 04:44 PM
#129
Ravenna
, Ohio
All the concern about the Load Index ov 108 vs 109 when in reality this translates to 3%.
How many are confident that their pressure gauge is accurate to better than 3%?
Have you confirmed the individual load on each tire is within 3% of a 50/50 side to side load balance or 3% axle to axle variation?
If not then why are you worrying about 3% more load capacity?
12-13-2015, 05:09 PM
#130
Green Cove Springs
Speaking of tire pressure gauges, I'd love to know of a good one. I'm not actually happy with any of the gauges I've seen so far. Each one returns a different value for the same tire. Not happy. I want a gauge that's precise, accurate, and easy to use. I have yet to see one that fits all three requirements.
12-13-2015, 06:15 PM
#131
Mantua
, Ohio
If you use the same gauge for each tire, the difference will show. As far as the three percent goes, then why are we worrying about ten percent. If the gauge is inaccurate then it will have the same error for each tire, to be used for comparison.
12-14-2015, 02:37 AM
#132
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
I use this LongAcre racing products digital tire gage (0-125 psi) and these folks often have special sale prices on their units. It reads in 0.5 psi increments and is accurate to 0.5 psi or 0.3%. There are more elaborate models listed.
Longacre Pro Digital Tire Pressure Gauge 53028
12-14-2015, 06:02 AM
#133
Tavares
The last few years, I've been replacing my tire pressure gauges annually.
What I do is to write "January 2016" (for example) using a Sharpie on the body of the gauge. This gives me a reminder to get it replaced.
I've been looking over options for 2016, and I've had this one in my cart on Amazon, based on its features and good reviews:
http://www.amazon.com/TEKTON-5941-Di...cm_wl_huc_item
12-14-2015, 07:16 AM
#134
2013 27' FB International
El Dorado Hills
Originally Posted by Llando88
The last few years, I've been replacing my tire pressure gauges annually.[/url]
Please explain why? This practice seems wasteful. The digital unit you reference seems very accurate. I bought the two pack. One for my truck and one for my wife's car. I tested both together on the same tires and read identical, to 0.5 psi. They say the battery lasts 3 years.
12-14-2015, 09:06 AM
#135
Ravenna
, Ohio
Here is what I have used and recommended for years. Have tested them myself against ISO standard laboratory gauges and found them to be withing 0.5 psi.
An excellent tire pressure gauge
The Accutire MS-4021B digital tire pressure gauge has an easy-to-read LCD display that provides pressure readings from 5-150 PSI. It’s ergonomically designed with an angled head and a rubber-coated easy-grip handle. If you forget to turn off the gauge, don't worry, it will automatically shut off. The included lithium battery never needs to be recharged or replaced. And all this for about than $13! Learn more or order from Amazon.
Note. I do not work for or get a commission on any sales of the Accutire gauge.
I have also written on gauges a number of times on my blog. Simply check the list of labels
You don't have to spend $50 or $100 to get a good gauge.
12-14-2015, 11:36 AM
#136
Tavares
The same reason I switch out the battery on the smoke detectors annually.
I really don't want to be checking my tires in the middle of nowhere, and think, gee, I could have saved $10, but my gauge isn't working.
I forgot to add, I keep the old gauge around for the year, also, because "Two is one, one is none."
Your mileage may vary, of course.
12-14-2015, 11:48 AM
#137
Liberty Corner
, New Jersey
I use the Accutire and really like it. Glad to hear it is actually accurate. I find that the TPS system I use registers 2 psi less so I go by the Accurate.
12-14-2015, 06:17 PM
#138
El Dorado Hills
I have the Accutire too. Also noticed the same 2 or 3 psi difference in the TPMS reading. Also still have Marathons, thus the extra diligence.
12-15-2015, 01:24 PM
#139
Ravenna
, Ohio
and if the gauge is reading 5 or 10 psi high you will think you have more load capacity that you need so will be in fact overloading your tires.
12-15-2015, 01:26 PM
#140
Ravenna
, Ohio
People seem to forget that TPMS is primarily to warn of a pressure loss and may not be accurate enough if you are within 3% of your tire load limits.
I would go with the PSI reading from the Accutire for knowing the pressure but rely on my TPMS for warning if there is a pressure loss.
