Old 12-04-2015, 05:08 PM   #85
Ravenna , Ohio
Originally Posted by r carl View Post
I blame the engineers of the cheap tires.
Do you mean the engineers that tell people to never exceed 65 mph (like the guy with TT that passed me while I was doing 75 today)?
or could it be the engineers that suggest you allow a minimum of 10% load margin on static loading of individual tires to allow for side loading?
or maybe the engineers that suggest you always run the tire sidewall max in tires in tandem or triple axle application?
perhaps the engineers that tell you to run a TPMS.
Ya probably it's those engineers fault.
Tireman9 is offline   Reply With Quote
Old 12-05-2015, 07:54 AM   #86
richw46's Avatar
Lexington , Kentucky
I think it's the astronomers, it's their fault. We should burn down the observatories to prevent this from ever happening again.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 12-06-2015, 12:43 PM   #87
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Hope that by blaming the astronomers for this, you don't think the phase of the moon is involved.
The folks to blame are whoever it is that specifies nice big white on black lettering for the tire name and the little itty bitty black on black lettering/code for the load rating, tire pressure, mfg location, and date of mfg info.
Thanks or all the tech supplied. It does help make a bit of sense out of all the noise.
Just remember that if I pass you at 75, I'm only using about 20% of the 30% safety margin the engineer should have built into the design. And if I'm blocking your lane at 55, then maybe there is another safety factor in play. Thanks for your consideration. Pat
Old 12-06-2015, 05:22 PM   #88
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I wont buy ST tires on the account of their 12,000 mile life expectancy.
That is ridiculous! Somebody isn't trying. This is not 1965.
Brevi tempore!
Old 12-06-2015, 05:59 PM   #89
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Once the trailer rolls off the production line and gets weighed, the dealer's bank account is charged for the trailer. The factory is only concerned with tires on the line and basically across the scales. Thus the cheapest possible tire good for less than a mile?
Stale tires are also often installed by Airstream when I saw 6 month old tires on my Classic that was 10 days off the production line.
Just saying, the customer gets left holding the tire carcus.
switz is online now   Reply With Quote
Old 12-06-2015, 09:54 PM   #90
Storm Master
Ampman's Avatar
2005 25' Classic
The current offering of ST tires should be designated Short Term tires only considering how cheaply and poorly constructed they are. The hype and labeling from the manufacturers are just lipstick on a pig. I too was fooled in my earlier ignorant state of mind. I now consider them manufacturer moving tires only. Meaning they are the cheapest tires put on the trailers to get them from the factory to the dealer and no more. Kind of like the tires they use on manufactured housing and then removed once the house is set up. Maybe they are ok for a little utility trailer to haul around stuff and no more. Manufactures should step their game up and build a better tire. No science to back it up, just personal experience and lots of shared grief on this and other forums. Buyers beware.
Ampman is offline   Reply With Quote
Old 12-07-2015, 07:50 AM   #91
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
I am just on trip home from California. Due to a last minute trailer change I am running on Marathons for the first time in many years. I am only towing a 28' this trip and so I am running the Marathons relatively soft at 45 PSI. Still it is amazing how much more things move around in the trailer with them.
So far no flats though, oh darn I wish I had not said that.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-07-2015, 04:39 PM   #92
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
If you are running 45 psi, it won't be long!
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 12-07-2015, 11:39 PM   #93
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Originally Posted by Andrew T View Post
For your 27' going to 15" Michelins P235/75R x 15" XL tires is a less expensive and better choice than going to 16's. The 15's are equivalent of a load range "C" tire so they ride much smoother than the Load Range "D" 16" tires. On the 27 you can tow with these at 45 PSI instead of the 65 you are running now. This is much friendlier to the Airstream. We have put on a couple of thousand of these now, absolutely no issue with them.
Andrew T
Thanks for this, Andrew, much appreciated. We have an International Signature 27FB, and this sounds like an interesting option when we replace our GYMs.
Rocinante is our 2014 International Signature 27FB
Old 12-08-2015, 07:35 AM   #94
richw46's Avatar
Andrew T
Why are you running them at 45 psi? You know that's going to build up a lot of heat, right? I'll bet that the AS manual says to have them at least at 50, maybe more. Mine has a warning to have them at 50 posted right above the wheel well.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 12-08-2015, 08:47 AM   #95
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
My AS manual says 65 lbs per tire, which is same as max pressure per sidewall. I'm guessing Andy is taking his direction from a manufacturer inflation vs load table and found the 45 lbs is sufficient for that specific trailer per it's scaled weight. What I'm unsure about is how that hurts sidewall stress during sharp turns as the tires scrub.
kscherzi is offline   Reply With Quote
Old 12-08-2015, 09:07 AM   #96
richw46's Avatar
From everything I've read online about ST tires, the lower the pressure the more heat is created. At the Goodyear site they tell you that the max speed for ST tires is 65 but if you add another 10 lbs. of air you can go up to 70. The additional air will put less tire on the road and therefore create less heat.
I would always go with what the tire manufacturer says. My AS manual says 50 lbs. pressure for its load. I travel at 60, sometimes 65, in the AS. My boat trailer has ST tires and I overinflate those to 60 lbs. so I can travel at 70. I can't imagine running a big trailer at 45 lbs. psi. I think that's looking for a tire problem.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 12-08-2015, 09:50 AM   #97
2016 25' Flying Cloud
Holly Springs , Mississippi
The CanAm boys have a zillion years' experience with all sorts of trailers and tires and tow vehicles. I'll take their experience and suggestions any day...
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 12-08-2015, 10:13 AM   #98
Rivet Slave
Rocinante's Avatar
Stop, do not pass go, do not collect $200. Please back up and read the thread again.
Andrew is talking about different tires, not the GYM ST tires that have a big "65" on the sidewall.
Bad Marathon, Bad Marathon ROBERTSUNRUS Tires 45 11-01-2015 03:46 PM
weird electrical problems Chuck Electrical - Systems, Generators, Batteries & Solar 11 10-04-2005 02:18 PM
Weird aluminum on endcaps? Ferroequine Ribs, Skins & Rivets 4 05-16-2005 12:41 AM
Weird off topic request Jim & Susan Off Topic Forum 15 05-12-2005 01:00 PM
Forum Acting Weird Tonight Big Dee Forum Admin, News and Member Account Info 1 05-12-2004 07:44 PM
