12-28-2015, 09:19 AM
#181
Ravenna
, Ohio
Originally Posted by CapriRacer
Just a couple of thoughts:
1) It would be highly unusual if all 4 tires on a travel trailer carried the same load. There is front to rear and side to side variation. The conservative guy in me says the worst case is 115% of the average.
Reasonable IMO
2) ST tires are speed restricted to 65 mph. In order to operate at 85 mph (the value I think should be used by trailer manufacturers), the load table values would need to be reduced by 20%.
I would limit to 75 mph as I have seen no data to support operation in tt usage at any speed higher than 75, but would no oppose a reduction in static loading margin to 15% to 20% below maximum
3) My experience says that tires should not be operated at more than 85% of their rated load (which includes those 2 things above).
YUP
So I think the calculation is much more complex.
In addition to the above I would change the DOT requirements for ST tires to be the same test procedures as 571.139 which was developed in 2001-2003 rather than continue to use section 571.109 which is over 60 years old and does not reflect today's highway speed or available tire technology.
12-29-2015, 07:49 AM
#182
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Per my scales weighing the individual Classic tires:
_______Street____Curb
Front.....2034........2042
Rear......1921........2062
Weight drop on street side rear is after replacing the stock six gallon water heater with a lighter weight instant on Truma AquaGo comfort unit and no stored water.
We installed the 16" Michelins and 16" SenDel wheels as soon as the trailer came off the dealer lot. The 2,680 load pound rating of the Michelin tire provides a greater safety margin than the GYM ST tire with a 2,540 rating with the more important information of a better service history with the Michelin tires.
The Eddie Bauer trailers had the Michelin/SenDel option for several years before the more wide spread after market adoption of this combination on other models. Now the factory installs this combination as standard on the 2015 and later Classics that have a 10,000 pound GVW with a pair of 5,000 pound rated axles.
As I said more than two years ago in late 2013, installation of the same Michelin LT225/75R16/E LTX M/S2 ( P/N 05681) tires and SenDel T03-66655T wheels that the factory has on display for sale at the service center at Jackson Center provided implicit approval of this combination in terms of any potential warranty issues in the suspension system.
12-29-2015, 01:19 PM
#183
2019 27' Tommy Bahama
London
, Ontario
Way back in the late 80's Airstream built the first fifth wheels ,the Argosy and later the Airstream version. They had the first Bias Ply ST tires on them rated at 2540 pounds. They were loaded to max and were blowing every few hundred miles. At the time there wasn't a 16" tire that would fit and we could not get a 16.5" rim with the right offset and bolt pattern.
We had to try something so we put on the 7.00 x 15" LT radials we used on Airstream trailers in those days. They were only rated at 2040 pounds so they were quite overloaded yet we never saw any failures, it was only 3 units but still they ran a lot of miles.
Andrew T
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
12-30-2015, 08:19 AM
#184
2013 31' Classic
billings
, Montana
My 1973 23' avion came with G-78/15 jumbo, after they give out 13 years later we used 225/75/15 P and never had any tire problems,the trailer was around 6600 lbs loaded I believe.
12-30-2015, 09:28 AM
#185
Mantua
, Ohio
Funny, my 84 30 foot Avion came from the factory with H78/15 or 700/15LT tires on it. Was this before ST tires?gvw is 8500 pounds, dual axle.
12-30-2015, 10:35 AM
#186
1987 Avion 34W owner
Good Ol'
, USA
Here is the ID plate from our 1987 Avion 34W. Specified ST tires back then.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
12-30-2015, 11:01 AM
#187
1994 30' Excella
alexandria
, Kentucky
Wow "H78 x 15 ST C" , 9500 GVWR - thats like an elephant riding on lawn mower tires
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
12-30-2015, 12:17 PM
#188
2012 27' Flying Cloud
W
, New England
Unless the 34 has triple axles. 6 of those tires would be over 12,000# carrying capacity.
Is it a double or triple?
12-30-2015, 12:26 PM
#189
Mantua
, Ohio
Triple axles.
12-30-2015, 12:29 PM
#190
W
, New England
Triple axles.
Well there you go! No problem! 😃
12-31-2015, 11:03 PM
#191
2016 27' Eddie Bauer
Plantersville
looks completely normal, a Goodyear Marathon tire made in China. I have had this exact problem before. If you switch to a better brand this will go away. Nothing new here.
