Old 09-28-2010, 09:06 AM   #15
Jackson , Wisconsin
Originally Posted by JBinKC View Post
Friends: Some tire-changing facts learned the hard way this weekend: 1.) Get rid of 12-point sockets in favor of six-point sockets so you don't round over the lug nuts. 2.) Before your next trip, loosen each lug and re-tighten to the correct torque. 3.) A breaker bar doesn't give you much more torque than a spanner wrench. So try to put the breaker bar handle in the spanner wrench for more torque. (Shouldn't be necessary if your lugs are correctly torqued.) 4.) Make sure you have high-pressure valve stems. Best wishes, John
Good advice. Don't only make sure you have high pressure valve stems, check the joints/edges of the valve stems to make sure they are healthy. The valve stem is often the culprit to a leaky tire.
streamair is offline   Reply With Quote
Old 09-28-2010, 09:08 AM   #16
Jackson , Wisconsin
That certainly is not a dry-rot crack. If it were, it would be accompanied by other dry-rot cracks around it.
Old 09-28-2010, 11:09 AM   #17
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Destroyed tire looks a lot like my GYM tread separation - Hmm?
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 09-28-2010, 11:56 AM   #18
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Seeing that shredded tire pic gave me the heebie-jeebies... bad memories... good reason to have a TPMS
Ditto on the trailer performance... almost didn't even realize there was a problem... 'cept when I glanced in the mirror, and saw nuggets flinging off from the side of the trailer...
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 09-28-2010, 12:16 PM   #19
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
What kind of hitch are you using? As a single-axle owner myself, a blown tire is a big concern of mine. Glad to hear your rig handled it so well.
Stephanie
