Old 06-07-2016, 12:18 PM   #57
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Originally Posted by Rocinante View Post
I just heard back from Michelin customer care regarding availability on the new Michelin Defender LTX M/S tires in the size 235/75R15 109T:
"Thank you for your email and your interest in the Michelin Defender LTX M/S tires. Since this is a new tire line some of the sizes are not yet available. Our records indicate that size 235/75R15 will launch on the first week of June. This means that dealers should be able to place an order at that time."
The last time I asked, Michelin gave me an "end of March" date. <sigh>
Oh, and like many others, when I called Costco to ask about putting these on a trailer they said two things, which I've paraphrased: (1) we don't work on trailers though we can mount the tires on rims if you bring them in, and (2) if you bring in rims and have us mount / balance the tires for you, don't tell us what vehicle you'll put these on because we'll freak out.
So, we won't be using Costco. I have neither the time nor the patience to use our "Trailer Aid" ramp to swap each rim myself, one at a time, unless it's a roadside emergency. Even then I'd try AAA first because we have their RV service option. Hopefully, when the tires become available, we can get Discount Tire to do the deed.
Just ordered a set the new Michelin Defender LTX M/S 235/75R15/XL 109T tires from Discount Tire in our area. They are finally available, so we'll have them installed on Friday if all goes according to plan. There's even a $70 rebate in effect thru Saturday based on buying 4 tires.
They will mount, balance and sell us a road hazard warranty. The only thing he asked was the GVWR for the trailer (7600). He did the math and said again he would be fine with putting them on for us.
So by this weekend we'll have our new tires and Centramatics mounted. Then I'll just reprogram the TPMS for the lower pressure (44-45 PSI is the number I've been seeing here on the forum) and we we'll be good to go.
Rocinante is our 2014 International Signature 27FB
Old 06-08-2016, 10:14 PM   #58
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The math does work out pretty well for a 27FB.
7,600 pounds GVW - 770 pounds literature tongue weight = 6,830 pounds
6,830 pounds divided by 4 tires = 1,707 pounds per tire.
Based on the older 15" Michelins I have on the 23D derated pressure of 1,983 pounds, the tires are loaded to 86% of capacity in the example above. That percentage improves (tire load decreases and so does the tire load percentage) with the actual tongue weight being higher.
switz is online now   Reply With Quote
Upgrade to 16" wheels and tires 1975 Argosy 24 chadloose Wheels, Hubs & Bearings 7 04-24-2013 04:50 AM
Upgrade to 16 inch Wheels and Tires ddruker 1999 Safari 3 03-04-2013 04:18 PM
16'' wheels and tires upgrade on older Airstream woodfox45 Tires 9 03-03-2012 11:16 PM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
