Old 03-09-2016, 02:57 PM   #15
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Originally Posted by franklyfrank View Post
-- snip -- Michelin LTX MS/2 P235 R15 T-108 -- snip -- without the hassle of changing wheels. -- snip -- load rating, 2183 lbs at 50 psi.
Unless you have a 23 with 14in original equipment wheels. Then you have to replace the 14s with 15in wheels before you can install that sweet tire. Note this tire is a XL P tire, which is an extra load passenger car tire. It gets derated by 10% when used for trailer service. But since the 23 gross weight is around 1500#s per tire, there is no problem with a capacity of 1967#s per tire.
Travel safe. Pat
PKI is online now   Reply With Quote
Old 03-09-2016, 04:12 PM   #16
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Actually I think a C load rating is 50 psi. A D is 65 psi.
Bill M. is online now   Reply With Quote
Old 03-09-2016, 04:28 PM   #17
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
The new Michelin Defender tire 235/75R15 has a higher load rating than the current Defender, so even after the derating of 10% it will de a better fit for all 23 & 25 ft Airstreams. It hits the market this month & that's why I'm holding off buying the Maxxis ST tire, just can't decide!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 03-09-2016, 05:12 PM   #18
bullet661's Avatar
2014 30' FB FC Bunk
Fresno , California
I just upgraded to the 16" wheels and Michelin tires and besides the reasons already mentioned I'm looking foreword to the increased ground clearance. I've drug the rear skids once and that wasn't a good feeling.
bullet661 is offline   Reply With Quote
Old 03-09-2016, 05:13 PM   #19
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by J. Morgan View Post
My 15" tires are rated at 2040 lbs each.
This leaves me with over 2,000 lbs to spare.
Talis gentium ceciderunt.
\MY Michelins are rated for 2100+ lbs. each, for a 30 Flying cloud that grosses at 8800 lbs. leaving me short about 400 lb.s at gross.
Means that I cannot load the FC to max, although I seldom do anyway.
MelGoddard is offline   Reply With Quote
Old 03-09-2016, 05:37 PM   #20
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Remember, all of the trailer weight does not sit on your trailer tires.
Old 03-09-2016, 07:20 PM   #21
Holly Springs , Mississippi
Great point.
So in Mel's case a trailer with GVW of 8,800 lbs., less tongue weight (carried by TV) of, say, 1,000 lbs -- so his tires must carry 7,800 lbs -- a 600 lb. safety margin.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 03-09-2016, 08:30 PM   #22
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Originally Posted by jcole View Post
I am also thinking of replacing my 15" GYM on my single axle 2016 Sport 22FB to the Loadstar ST225/75R-15 Radial Load range E just to get the Xtra 2 Ply from 8 to 10. No need to change wheels because overall diameter is just .1" larger than the 15" Marathons. Also a few hundred pounds of Xtra weight carrying does not hurt.
Except that, in order to gain any benefit from the additional capacity of load range E tires, you will have to run them at the higher inflation rate of 85 lbs. Run them at 60-65 lbs, and you will only have the weight capacity of a D rated tire. The minimal suspension travel that Airstream trailers have requires that the tires absorb impacts to protect the trailer. Running E rated tires at 85 Lbs will not provide the cushioning needed by your relatively light trailer.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 03-10-2016, 12:34 AM   #23
Swanstreaming
swan's Avatar
2014 28' International
Zionsville , Indiana
Send a message via Skype™ to swan
There are so many threads about this stuff... I'm still scratching my head, though. I don't understand why everyone wants to max out their tire inflations.
I have a 28' 2013 International, which is dual axle, with the stock Goodyear ST225/75R15s. I had my trailer weighed at a truck stop when we were loaded up on a 6-month trip. It came in just under 7,000 lbs.
If you divide 7000/4, you come up with each tire being loaded with 1750lbs. If you look at Goodyear's inflation guide for those tires, it recommends 35lbs of pressure for 1760lbs of weight, cold—even thought the tire can take 65lbs of pressure, for a max rating of 2540lbs. Airstream says the trailer's loaded weight is 7500lbs. Divide that by 4, and you get 1875, which would be 40lbs cold. So, I should be running between 35 and 40 lbs cold, if I want to error on the cautious side. Why are people jacking them up to 65lbs?
Is there something I'm missing?
Instagram.com/swanstreaming
swan is offline   Reply With Quote
Old 03-10-2016, 04:41 AM   #24
SeaLevel's Avatar
Jupiter , Florida
Good questions, and I am curious to find out. Here is a link to the information you referenced.
http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
SeaLevel is offline   Reply With Quote
Old 03-10-2016, 05:09 AM   #25
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by Bob662 View Post
Great point.
Don't forget that the weight on the tires is NOT evenly distributed. I'm using a 15% variation until I find better data.
CapriRacer is offline   Reply With Quote
Old 03-10-2016, 05:10 AM   #26
CapriRacer
CapriRacer's Avatar
I'm in the , US
Great point.
Also, don't forget to provide a margin of unused capacity - commonly called "Reserve Capacity". I use 15% there as well!
Old 03-10-2016, 06:22 AM   #27
2016 22' Sport
Glenville , New York
Ok, I can understand the minimal suspension impact why the 60-65Lbs instead of the 85 Lbs. In our case since we do not travel with any liquids in any tanks & put most if not all of our travel needs in our tow vehicle which is a Nissan 3500 HD cargo van I am not concerned with the xtra weight. I just want to get away from the Goodyear brand hoping the added 2 ply will give a little added protection from a blowout & still stay with a tire designated for travel trailer use. I am also thinking since the added weight we would add to the dry(empty) trailer weight will not exceed a few hundred pounds maybe its better to go with a Michelin 15" that just meets the load capacity in which we travel with ...... any thoughts ???
jcole is offline   Reply With Quote
Old 03-10-2016, 08:17 AM   #28
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We installed the 15" Michelin LTX (P) 235/75R15 XL tires on the stock wheels of the 2013 25FB with no problems. Going from 14" tires and wheels to the same 15" tires on the 23D required new 15" SenDel T03-56545T wheels as well with the five hole pattern for the 10" brake drums.
Going to the 16" tires and wheels on our 2014 Classic required new wheels as well and we acquired the same tires and wheels Airstream is now installing on 2015 and later Classics and the Eddie Bauer models.
Upgrade to 16" wheels and tires 1975 Argosy 24 chadloose Wheels, Hubs & Bearings 7 04-24-2013 04:50 AM
Upgrade to 16 inch Wheels and Tires ddruker 1999 Safari 3 03-04-2013 04:18 PM
16'' wheels and tires upgrade on older Airstream woodfox45 Tires 9 03-03-2012 11:16 PM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
